Введение
In this guide, the reader will be stepped through the process of removing and replacing the base panel on the iHome iBT16. This is a prerequisite guide to most replacement guides, due to it being the access to the motherboard.
Выберете то, что вам нужно
Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
Using a lever like motion, push the opening tool down thus lifting the plate
