iHome iBT16 Motherboard Replacement
Выберете то, что вам нужно
  1. iHome iBT16 Motherboard Replacement, Base Plate: шаг 1, изображение 1 из 2 iHome iBT16 Motherboard Replacement, Base Plate: шаг 1, изображение 2 из 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Motherboard Replacement: шаг 2, изображение 1 из 2 iHome iBT16 Motherboard Replacement: шаг 2, изображение 2 из 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome iBT16 Motherboard Replacement, Motherboard: шаг 3, изображение 1 из 3 iHome iBT16 Motherboard Replacement, Motherboard: шаг 3, изображение 2 из 3 iHome iBT16 Motherboard Replacement, Motherboard: шаг 3, изображение 3 из 3
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
  4. iHome iBT16 Motherboard Replacement: шаг 4, изображение 1 из 2 iHome iBT16 Motherboard Replacement: шаг 4, изображение 2 из 2
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
  5. iHome iBT16 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Remove the plastic cover from the power switch actuator on the motherboard.
Заключение
Joseph Hazel
Участник с: 03/24/17
329 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 Участник UMass Dartmouth, Team S8-G4, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G4
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 1,136
