Введение
This guide will help you replace the outer case of your iHome iH27B in just a few easy steps.
Выберете то, что вам нужно
Remove any iPod or apple music device connected to the iHome and unplug from any power source.
Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
Remove the plastic slide from its location and set it aside.
Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
Set the plastic covering and the watch battery aside.
Remove the following screws:
Eight 10 mm using the Phillips #0 on the bottom of your device.
Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
You should have visible access to most of the components inside the iHome now.
