iHome iH27B Outer Case Replacement
Выберете то, что вам нужно
  1. iHome iH27B Outer Case Replacement, Outer Case: шаг 1, изображение 1 из 1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B Outer Case Replacement: шаг 2, изображение 1 из 3 iHome iH27B Outer Case Replacement: шаг 2, изображение 2 из 3 iHome iH27B Outer Case Replacement: шаг 2, изображение 3 из 3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B Outer Case Replacement: шаг 3, изображение 1 из 1
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B Outer Case Replacement: шаг 4, изображение 1 из 1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B Outer Case Replacement: шаг 5, изображение 1 из 1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
Заключение
John Kraemer
Участник с: 10/09/12
76 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 3-21, Amido Fall 2012 Участник Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 498
