Введение
The batteries found at the bottom of the iHome has no power leading to the device powering on, these are backup batteries. If the batteries are corroded, please be careful and keep the corrosion away from your eyes and mouth as it can be dangerous.
Выберете то, что вам нужно
Using your finger, pry the tab on the battery cover to remove the battery cover on the back of the iHome to access the batteries.
With the battery panel off, remove the batteries. Use your hands or a plastic spudger to remove the batteries.
When removing the batteries make sure to remove corrosion. Wear gloves when removing corrosion and use proper disposal.
