Введение
This is a cleaning and replacement guide for the iHome iH5.
  1. Remove the eight screws from the bottom side of the iHome.
    • Remove the eight screws from the bottom side of the iHome.
  2. Remove the cover to expose the inside.
    • Remove the cover to expose the inside.
    • With pliers, or tweezers,if needed, remove the three wire harnesses by gently pulling straight up on them.
  3. Remove the 5 screws with a #2 Phillips screwdriver.
    • Remove the 5 screws with a #2 Phillips screwdriver.
  4. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Remove all wire harnesses from the bottom of the board. There eight wire harnesses.
    • Remove all wire harnesses from the bottom of the board. There eight wire harnesses.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
  6. Remove the two screws from the speakers with a #2 Phillips screwdriver. Turn the device on its front side and remove the two screws with a #2 Phillips screwdriver. Pull the speaker up from the back as shown with the speaker on the right. Then pull the speaker straight back as shown with the speaker on the left.
    • Remove the two screws from the speakers with a #2 Phillips screwdriver.
    • Turn the device on its front side and remove the two screws with a #2 Phillips screwdriver.
    • Pull the speaker up from the back as shown with the speaker on the right. Then pull the speaker straight back as shown with the speaker on the left.
  7. Remove the front piece by pulling up until it hits the plastic pieces sticking out from the display screen. Then pull it out horizontally from the device.
    • Remove the front piece by pulling up until it hits the plastic pieces sticking out from the display screen. Then pull it out horizontally from the device.
  8. Remove the three screw from the dial with a #2 Phillips screwdriver.
    • Remove the three screw from the dial with a #2 Phillips screwdriver.
  9. Pull back the circuit board to access the plastic piece.
    • Pull back the circuit board to access the plastic piece.
    • Lift to separate the plastic piece from the dial.
    • Replace the broken piece.
Заключение
3 участников успешно повторили данное руководство.
Maggie Hill
Участник с: 20.03.2014
379 Репутация
Автор 3 руководств
Команда
New Mexico State, Team 1-6, Easley Spring 2014 Member of New Mexico State, Team 1-6, Easley Spring 2014
NMSU-EASLEY-S14S1G6
5 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 2
За всё время: 701
