Введение
Use this guide to replace your iHome iP1's damaged or faulty 30-pin connector. This connector is located on the iPod/iPhone dock and is used to connect your Apple device to your iHome iP1.
Выберете то, что вам нужно
Remove the dock cover by grabbing its sides and pulling it up and away from the faceplate.
Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
Rotate the iHome so that the speakers are facing you.
Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
Rotate the iHome so that the speakers are once again facing away from you and the motherboard is still exposed.
Unplug the wide red/white/black wire bundle from the lower right-hand corner of the motherboard by pulling it out of their connection.
Rotate the iHome iP1 so that the speakers are now facing you.
Remove both of the speaker covers by pulling them off of the faceplate.
Unscrew the twelve 14.5 mm Phillips #2 screws holding the faceplate to the speaker housing. (There are six screws connecting the faceplate to each speaker.)
Detach the 30-pin connector from the dock housing by pushing it through the slot which it sticks out of.
Remove the 30-pin connector from the iHome by pulling the bundle of cables attached to it through the center hole in the faceplate.
Еще один человек закончил это руководство.
4 Комментариев
Where can you buy a new pin connector?
Where can I buy a new pin connector?
