Введение
Prerequisite-only guide to remove the hard drive in an iMac 27" 2017.
  1. Pull straight up on the SATA data/power cable to disconnect it from the drive. Pull straight up on the SATA data/power cable to disconnect it from the drive.
    • Pull straight up on the SATA data/power cable to disconnect it from the drive.
  2. Remove two 7.3 mm T8 screws securing the left hard drive bracket to the rear case.
    • Remove two 7.3 mm T8 screws securing the left hard drive bracket to the rear case.
  3. Grab the hard drive and left hard drive bracket together. Tilt the left side up away from the rear case, and slide the assembly to the left. Remove the hard drive and left hard drive bracket from the iMac.
    • Grab the hard drive and left hard drive bracket together.
    • Tilt the left side up away from the rear case, and slide the assembly to the left.
    • Remove the hard drive and left hard drive bracket from the iMac.
  4. Remove the left hard drive bracket. Remove the left hard drive bracket.
    • Remove the left hard drive bracket.
Заключение
Adam O'Camb
Участник с: 11.04.2015
142 328 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Community
137 членов
Автор 16 711 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 30
