Введение
Adding RAM will improve performance, especially when multitasking.
Выберете то, что вам нужно
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
Remove the four 28.07mm Torx #15 screws from the lower case.
Open the base by carefully pulling straight off, do not rotate the cover.
You can skip steps 7-9; there is no need to disconnect any internal wiring or RAM. Crack open the base a couple of inches (it doesn't really rotate, just pull it out), and the PRAM battery will be right under your nose. It's no problem to pop it out with your fingers and put the new one in. Just make sure that you note the positive and negative terminals on the old one, and put the new one in the same way.
No one mentioned the need for thermal paste in the reassembly...
Thermal paste? Where would you put that? As I understand it there's no need for that anywhere other than the CPU/Heatsync
There's a post (or block really) that connects the cpu heatsink to the upper part of the metal shell that is just to the right (facing the imac) of the drive door. Upon reassembly it's best to clean the matching surfaces and reapply thermal paste to that upper post.
Joe Pena -
what's with the apparent loose black wire visible in step 6 & 7 ?? same as the loose wire just sitting there in step 3 ( which was like that on mine, just loose.....? )
I hear that wire is bluetooth hook up.. my model has the other side but my board doesn't have the hook up... go fig :(
sean -
Squeeze the small black tab and wiggle gently to remove the colored power cable.
Grab both sides of the blue connector and firmly pull to remove it from the mother board.
It's a bit vague. That is, it explains where and how the memory module fits, but most importantly it does not. What type of DIMM memory it has to be and its speed as well as the process of not touching hands with the gold connectors of the memory module
Release the tabs on each side of the module by pulling them away from the internal RAM
19 участников успешно повторили данное руководство.
2 Комментариев
It's a bit vague. That is, it explains where and how one has access and how the said memory module fits, but most importantly it does not. What kind of memory are we referring to, just as it does not explain the type of memory it has to be and its speed as well as the process of not touching hands with the gold connectors of the memory module
Which memory bank is inside Bank 0 or Bank 1?
