Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Remove bottom housing to reveal the inside of the iMac.
Выберете то, что вам нужно
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
6 участников успешно повторили данное руководство.
Один комментарий
If you do this - don't you still need to apply a fresh coat of thermal paste to the exposed ends of the two heat-sink posts (that separate when you open a G4 flatpanel this far) - my understanding was that the machine would overheat and you'd be left with didley squat!!
Gregg :O)
