Инструменты
Запчасти
Детали не указаны.
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Remove the 2 torx 10mm screws on the EMI shield
Carefully remove shield and copper tape
Grasp the carrier with both hands on each side.
Remove the carrier by lifting up and out.
2 участников успешно повторили данное руководство.
Комментариев: 2
What two screws in step 6
We need a "action" shot; we need to show an actual screwdriver unscrewing the screw.
