iMac G4 17 800 MHz EMC 1936 LCD Replacement
Выберете то, что вам нужно
  1. iMac G4 17 800 MHz EMC 1936 LCD Replacement, LCD: шаг 1, изображение 1 из 1
    • Position the computer so that all three screws on the underside of the display are accessible. This may be upright or laid flat with the screen face down on a soft surface.
    • Be careful not to put any stress on the metal arm connecting the base to the display.
  2. iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 2, изображение 1 из 1
    • Unscrew the three underside 1.5 mm hex screws with the tight fitting, hexagonal screw head.
    • Be careful not to lose the screws as they will fall out when unscrewed completely.
  3. iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 3, изображение 1 из 1
    • Separate the front panel of display from base by firmly, but carefully, applying pressure upward. As a result, the two panels should slide apart.
    • This may be difficult and require more force than expected, but they will disassemble.
    • Once you feel the front panel beginning to slide upward, be careful not to separate the two sections more than a couple of inches. The two sections are connected by several cords that can easily break.
  4. iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 4, изображение 1 из 1
    • While the cords are still connected, access the inter-workings of the display from the top.
    • The red circle indicates the LED cable.
    • The blue circle indicates the inverter cable.
    • The yellow circle indicates TMDS connector.
  5. iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 5, изображение 1 из 1
    • Disconnect the inverter cable by grasping the chords on each side of the white connection and gently pull your hands away from each other.
    • There may be a strip of clear yellow tape over white connection. Gently remove it.
  6. iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 6, изображение 1 из 1
    • The next cord to unplug between the two panels of the display is the inverter cable. This will be located under the inverter closer to the bottom of the screen and will have only two cables connecting at a smaller white connection.
    • Go ahead and remove the yellow tape if it covers this connection.
    • Like the inverter cable, grasp each side of the white connection and gently unplug the inverter cable.
  7. iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 7, изображение 1 из 2 iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 7, изображение 2 из 2
    • The third, and final, cable you will need to unplug is the TMDS connector. This is located under a rectangular strip of black tape that has a gray and black cord coming out of one end.
    • Peel back the black tape, starting at the end with the cords protruding out.
    • Under the black tape, you will see the gray and black cords going into a connection that looks like it is wrapped in aluminum foil. Grasp that connection and pull carefully in the downward direction toward the bottom of the display.
  8. iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 8, изображение 1 из 2 iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 8, изображение 2 из 2
    • Now that you have unplugged all of the cables, you can lay the front panel of the display face down on a soft surface.
    • Next, you will unscrew the four 5 mm T-10 screws located at the corners of the display.
  9. iMac G4 17 800 MHz EMC 1936 LCD Replacement: шаг 9, изображение 1 из 1
    • Once the four screws are removed, the display is ready to be removed and the inverter is accessible.
Заключение
8 человек успешно провели ремонт по этому руководству.
Austin Krause
Участник с: 10/06/11
388 Репутация
Автор 2 руководств
Команду
Cal Poly, Team 21-22, Maness Fall 2011 Участник Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 членов
Автор 13 руководств
3Комментарии к руководству
For every step we need to have an action. Step 4 of dissasembling the screen does not have this.
In step 5 we remove the inverter cable, but in step 6 we say inverter cable... again . Is this true?
David Hunter - Ответить
It should say Status LED, not inverter.
Graham Davenport -
Very informative, just fished following this guide. my replacement LCD came with the bracket that is normally attached to the bezel, so i had one extra (no brainer) step
Graham Davenport - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 8
За последние 30 дней: 51
За всё время: 11,109
