iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement
Выберете то, что вам нужно
  1. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate: шаг 1, изображение 1 из 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: шаг 2, изображение 1 из 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: шаг 3, изображение 1 из 1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: шаг 4, изображение 1 из 2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: шаг 4, изображение 2 из 2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: шаг 5, изображение 1 из 2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: шаг 5, изображение 2 из 2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Logic Board Assembly: шаг 6, изображение 1 из 1
    • Gently remove the cables marked in red.
  7. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: шаг 7, изображение 1 из 1
    • Remove the three metal 10mm T-15 screws.
    • Remove the one nylon 10mm T-15 screw.
  8. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: шаг 8, изображение 1 из 1
    • Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
    i followed instructions and the logic board is stuck in there! can’t find any answers on the web either. any ideas?
    the biohazard - Ответить
Заключение
9 участников успешно повторили данное руководство.
Justin
Участник с: 10/05/11
303 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 21-22, Maness Fall 2011 Участник Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 членов
Автор 13 руководств
Один комментарий
We need to say what cables to remove in step 6 of Logic Board Assembly
Courtney - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 45
За всё время: 10,523
