Введение
Removing the logic board assembly to replace it with a new one.
Выберете то, что вам нужно
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
i followed instructions and the logic board is stuck in there! can’t find any answers on the web either. any ideas?
9 участников успешно повторили данное руководство.
