Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Removing an old or broken PRAM battery.
  1. Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. Loosen the four Phillips #0 screws.
    • Loosen the four Phillips #0 screws.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. Carefully remove the base access panel.
    • Carefully remove the base access panel.
  5. Remove the four 25mm T-15 screws. Remove the four 25mm T-15 screws.
    • Remove the four 25mm T-15 screws.
  6. Open the housing plate. Be gentle with the wires still connected to the logic board  so as not to ruin the cables.
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  7. Gently remove the battery from its holder using the plastic opening tool. Insert new battery.
    • Gently remove the battery from its holder using the plastic opening tool.
    • Insert new battery.
    • Clean and re-apply thermal paste to the heat sink areas circled in orange. See Step 15 in iMac G4 17" Model M9168LLA Hard Drive Replacement for better photos and description.
Заключение
8 участников успешно повторили данное руководство.
Justin
Участник с: 05.10.2011
271 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 21-22, Maness Fall 2011 Участник Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 членов
Автор 13 руководств
Комментариев: 2
We are not allowed to use screwdrivers to pry open stuff. Unfortunately, that is exactly what we did in step 6 of Dissasembling the back up battery
David Hunter - Ответить
Don't you need to replace the thermal paste?
adoug27 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 88
За всё время: 7,512
