Введение
Removing an old or broken PRAM battery.
Инструменты
Запчасти
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Gently remove the battery from its holder using the plastic opening tool.
Insert new battery.
8 участников успешно повторили данное руководство.
Комментариев: 2
We are not allowed to use screwdrivers to pry open stuff. Unfortunately, that is exactly what we did in step 6 of Dissasembling the back up battery
