Введение
Regain Bluetooth functionality by replacing your Bluetooth board.
Выберете то, что вам нужно
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly from the bottom edge of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
Bend a paper clip into a hook and use it to pull the Bluetooth board up off its socket on the logic board.
Use a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
10 участников успешно повторили данное руководство.
Один комментарий
WARNING: The last iMac G5 17" ALS (no isight) to be made does NOT have a dedicated bluetooth board.
I followed this guide and ended up removing the fax/data modem which is above the bluetooth board in this guide.
The last iMac G5's (17" no isight) to be made have a Airport Extreme/Bluetooth combo board:
http://www.applemacparts.co.uk/store/pow...
This is located to the right of the battery.
My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
paulfrancoeur - Ответить
The two outer screws each drive a locking bar that engage tabs on the rear panel.
They definitely need to be unscrewed.
Dale Stanbrough -
That chick MJ is sexy!!!!!
djmadcracker - Ответить
Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
Terry Mullane - Ответить
Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
James Janota - Ответить
Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
mary nicolazzo - Ответить
These are the easiest way to resolve the Wireless connectivity at my home. Thanks ifixit for sharing this.
Geek Squad - Ответить
