iMac G5 17" Model A1058 Inverter pinout 6 pin
  1. iMac G5 17" Model A1058 Inverter pinout 6 pin, iMac G5 17" Model A1058 Inverter pinout 6 pin: шаг 1, изображение 1 из 2 iMac G5 17" Model A1058 Inverter pinout 6 pin, iMac G5 17" Model A1058 Inverter pinout 6 pin: шаг 1, изображение 2 из 2
    • That is the G5 17" A1058 Inverter pinout with 6 pins. I took it down myself from the board with a multimeter and the ICs Datasheets.
    • 12v is the main soruse
    • GND is ground
    • 5V supplyes Op amp on the sheme that gives the niveau of backlight, It cant be lower than 5v so actualy it dosn't regulate the dimm of the light.
    • 5v The second line Gives the Enable signal ot the inverter
    • Dont connect. It goes to a gate of two mos transistors k72 SMD and is protected trought a diod directly after the pin. It should turn on these Transistors but when I give it supply, the backlight goes off and doesn't turn on back again when i remove the supply (I tried 5v) Fixed it with reset of the PSU.
    • 3.3 v. Again goes on set of MOS transistors. Their gates should be capable of taking up to 5-10 volts. But I decided to play it safe. It makes the backlight brighter( that is the light dimmer). Whitout it the backlight works but isnt brighter as it should.
Заключение
2 человек успешно провели ремонт по этому руководству.
Ogi
Участник с: 03/04/14
136 Репутация
1 руководство автора
Один комментарий
You connect the 5v without the GND? The GND is just connected to 12v??? I just see 1 cable making the 5v. HELP!
Lidia Batista - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 5,215
