Введение
Remove your midplane assembly to gain access to your display and front bezel.
Выберете то, что вам нужно
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly from the bottom edge of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Lift the optical drive near the connector to separate it from the logic board.
Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
Lift the optical drive out of your iMac.
Slide the inverter-to-display cable connector from under the metal clip on the midplane.
Disconnect the inverter-to-display cable connector by pulling it straight away from its socket.
Remove the single Phillips screw securing the inverter to the logic board.
Lift the inverter straight up off the pins on the logic board.
Disconnect the inverter cable from the logic board by pulling it straight up from its socket.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
While depressing the connector lock, insert the flat end of a heavy duty spudger into the gap between the power supply connector and its socket.
Twist the heavy duty spudger to slightly separate the connector from its socket.
Pull the power supply connector straight away from its socket on the logic board.
This step is very simple if you remove the power supply first.
Grab the power supply from each side and rotate its top edge toward yourself until it clears the logic board.
Lift the power supply out of the midplane.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
Remove the two Phillips screws securing the display data cable to the logic board.
Using its black pull tab, pull the display data cable connector straight up off its socket on the logic board.
Using its attached pull tab, lift the free edge of the midplane assembly slightly out of the front bezel.
Push the inverter-to-display cable connector through the hole in the midplane.
Lift the now-free midplane assembly out of the front bezel.
6 участников успешно повторили данное руководство.
