Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Replace your modem and re-introduce yourself to the joys of 56k.
Выберете то, что вам нужно
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly from the bottom edge of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
Push the spudger away from the AirPort card to disconnect the AirPort antenna.
Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
Slightly lift the AirPort bracket off the logic board.
De-route the AirPort antenna through the slot in the AirPort bracket.
Set the AirPort bracket aside.
Remove the two 5.5 mm T6 Torx screws securing the modem to the logic board.
Pry the modem straight up from its top edge to disconnect it from the logic board.
3 участников успешно повторили данное руководство.
