Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
iSight not working? Replace your camera board.
Выберете то, что вам нужно
Loosen the two Phillips screws securing the access door to your iMac.
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Lay your iMac stand-side down on a table.
Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
Lay the front bezel above the rest of the iMac.
If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
Lay the bezel front side down on a table.
If necessary, peel back the tape covering the camera board.
