Введение
The fan duct directs air across the heat sink on the logic board.
Запчасти
Детали не указаны.
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Remove the following two screws:
One 11 mm T10 Torx.
One 10.6 mm T8 Torx.
5 участников успешно повторили данное руководство.
