Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace your display inverter.
Выберете то, что вам нужно
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
Remove the following three screws securing the inverter to the chassis:
Two 7.9 mm Phillips.
One 26 mm Phillips.
Slide the inverter toward the edge of the mid-plane, then lift it out of the iMac.
Disconnect the large inverter cable connector from the inverter by pulling straight away from its socket.
Disconnect the small inverter cable connector by pulling it straight away from its socket.
Disconnect the hard drive thermal sensor cable from the thermal sensor board on the hard drive bracket by pulling the cable away from the heat sink.
Flip up the inverter cable cover from its left edge and lift it out of the chassis.
Remove the inverter cables from the inverter cable cover, and disconnect both connectors.
4 участников успешно повторили данное руководство.
