Выберете то, что вам нужно
Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
Pull the optical drive up by its white pull tab to disconnect it from the logic board.
Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
Lift the optical drive out of your iMac.
Почти готово!
Заключение
