Введение
Remove the rear panel to gain access to the innards of your iMac.
Выберете то, что вам нужно
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
13 человек успешно провели ремонт по этому руководству.
