Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Orient the iMac face-side down on a table with the bottom edge facing yourself.
Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
Turn the computer over.
Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
Инструмент, используемый на этом этапе:Plastic Cards$2.99-
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Lay your iMac stand-side down on a table.
Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
Lay the front bezel above the rest of the iMac.
If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
Tape the lower EMI shield up against the face of the display to keep it out of the way while you work.
Remove the two T6 Torx screws securing the display data cable connector to the logic board.
To disconnect the display data cable, grab its connector's black tab and pull it away from the face of the logic board.
Peel back the two EMI tape strips from the left and right edges of the display.
Remove the four recessed T10 Torx screws securing the display to the rear case.
Lift the lower edge of the display slightly out of the rear case.
Disconnect both inverter cables (shown in red) by pulling their connectors toward the bottom edge of your iMac.
Lift the display until it is nearly perpendicular to the rear case.
Disconnect the remaining two inverter cables (shown in red) by pulling their connectors toward the top edge of your iMac.
While holding the display perpendicular to the rear case, pull it upward to peel off the EMI shield stuck to its upper edge.
11 участников успешно повторили данное руководство.
