Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Disconnect the hard drive thermal sensor from the logic board by pulling its connector toward the top edge of your iMac.
Remove the two T10 Torx screws securing the hard drive bracket to the inverter.
Lift the left edge of the hard drive slightly, then pull it toward the left edge of the iMac.
Rotate the hard drive out of the rear case.
Disconnect the SATA data cable by pulling its connector away from the hard drive.
Disconnect the SATA power cable by pulling its connector away from the hard drive.
Remove the hard drive from the iMac.
