iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
Абсолютно необходимое руководство
Это руководство предназначено только для использования в качестве обязательного условия для других руководств. Оно не полностью само по себе.
  1. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement, Hard Drive: шаг 1, изображение 1 из 1
    • If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
  2. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Disconnect the hard drive thermal sensor by pulling its connector toward the top of your iMac.
    • When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
  3. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: шаг 3, изображение 1 из 2 iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: шаг 3, изображение 2 из 2
    • Pressing the top of the hard drive bracket down to release it from the rear case requires a substantial amount of force. We recommend laying your iMac stand-side down on a table to avoid knocking it over.
    • Press the hard drive bracket down toward the bottom edge of your iMac to free it from the rear case, then rotate the top of the drive toward yourself.
  4. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: шаг 4, изображение 1 из 2 iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: шаг 4, изображение 2 из 2
    • Rotate the hard drive toward yourself, then lift it up off its mounting pins.
    • The hard drive is still connected via the SATA cables.
    • When reinstalling your hard drive, be careful not to push the rubber grommets through the openings in the chassis with the lower hard drive pins as retrieving them may require logic board removal.
  5. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: шаг 5, изображение 1 из 1
    • Insert the flat end of a spudger between the SATA power cable connector and the edge of the hard drive.
    • Twist the spudger to separate the connector from the hard drive.
  6. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Pull the SATA power connector away from the hard drive.
  7. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: шаг 7, изображение 1 из 1
    • Disconnect the SATA data cable by pulling its connector away from the hard drive.
Заключение
4 участников успешно повторили данное руководство.
Один комментарий
Walter, I was working on a mid-2007 IMac (2133) and found your instructions helpful but not always complete or right. I have added some comments in some of the steps to clarify.
Pablo Guerrero - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 2,890
