Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
Remove the two fine-thread 7 mm T10 Torx screws securing the optical drive to the rear case.
Lift the free end of the optical drive slightly out of the rear case.
Remove the two 3.5 mm T6 Torx screws securing the optical drive connector to the optical drive.
Insert the flat end of a spudger between the optical drive connector and the body of the optical drive.
Twist the spudger to separate the connector from the optical drive.
Lift the optical drive out of the rear case and pull it away from the side of the rear case to release the strip of EMI tape attached to its surface.
