Введение
Restore your Bluetooth connectivity by replacing your Bluetooth board.
Выберете то, что вам нужно
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Инструмент, используемый на этом этапе:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Use the flat end of a spudger to pry the bluetooth antenna connector up off the bluetooth board.
Remove the single T6 Torx screw securing the Bluetooth board to the logic board.
Lift the Bluetooth board out of your iMac.
3 участников успешно повторили данное руководство.
Один комментарий
Is it possible to upgrade the bluetooth card with one for 4.0 bluetooth?
