Введение
Is your iMac's hard drive running a bit hot? Replace the hard drive fan and keep your hard drive cool.
Выберете то, что вам нужно
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Инструмент, используемый на этом этапе:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Pull the LCD temperature sensor connector straight up off its socket on the logic board.
(located at the top of the logic board on the 24")
Remove the two T6 Torx screws securing the display data cable to the logic board.
Use the attached black tab to pull the display data cable connector straight away from the logic board.
Remove the eight T8 Torx screws securing the display panel to the rear case.
Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
With the display panel still lifted, disconnect the four inverter cables.
(combined into one plug in on the 24")
Remove the single T10 Torx screw securing the right speaker to the rear case.
Disconnect the right speaker cable connector from the audio board by pulling it straight up from its socket.
Disconnect the optical drive fan connector from the audio board by pulling it straight away from its socket.
Gently lift the optical drive fan off the plastic posts protruding from the rear case.
Insert the flat end of a spudger into the gap between the optical drive data cable connector and its socket.
Twist the spudger to separate the connector from its socket.
Disconnect the microphone cable connector from the audio board by pulling it straight up from its socket.
Disconnect the following connectors:
Hard drive thermal sensor cable.
Optical drive thermal sensor cable.
Hard drive fan cable.
Disconnect the DC-in cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board.
Инструмент, используемый на этом этапе:Metal Spudger$2.99
Pull the SATA data cable straight up off the logic board.
Use the flat end of a spudger to pry both antenna connectors up off the AirPort Extreme card.
Disconnect the left speaker connector from the audio board by pulling it straight away from its socket.
Ambient temperature sensor cable.
Power button cable.
CPU fan cable.
Disconnect the camera cable connector from the logic board by pulling it straight up from its socket.
Use the flat end of a spudger to pry the bluetooth antenna connector up off the bluetooth board.
Use the sharp end of a spudger to peel the EMI tape off the headphone/microphone jacks.
Remove the following screws securing the logic board to the rear case:
Three fine-thread T10 Torx.
Six coarse-thread T10 Torx.
One longer coarse-thread T10 Torx.
Two coarse-thread T8 Torx.
Lift the logic board assembly out of the rear case, minding any cables or I/O ports that may get caught.
Gently lift the hard drive fan off the plastic pins protruding from the lower case.
3 участников успешно повторили данное руководство.
