iMac Intel 21.5" EMC 2389 Display Replacement
Выберете то, что вам нужно
  1. iMac Intel 21.5" EMC 2389 Display Replacement, Glass Panel: шаг 1, изображение 1 из 2 iMac Intel 21.5" EMC 2389 Display Replacement, Glass Panel: шаг 1, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Купить
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. iMac Intel 21.5" EMC 2389 Display Replacement: шаг 2, изображение 1 из 2 iMac Intel 21.5" EMC 2389 Display Replacement: шаг 2, изображение 2 из 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 21.5" EMC 2389 Display Replacement, Display: шаг 3, изображение 1 из 3 iMac Intel 21.5" EMC 2389 Display Replacement, Display: шаг 3, изображение 2 из 3 iMac Intel 21.5" EMC 2389 Display Replacement, Display: шаг 3, изображение 3 из 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  4. iMac Intel 21.5" EMC 2389 Display Replacement: шаг 4, изображение 1 из 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board.
  5. iMac Intel 21.5" EMC 2389 Display Replacement: шаг 5, изображение 1 из 2 iMac Intel 21.5" EMC 2389 Display Replacement: шаг 5, изображение 2 из 2
    • Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
  6. iMac Intel 21.5" EMC 2389 Display Replacement: шаг 6, изображение 1 из 2 iMac Intel 21.5" EMC 2389 Display Replacement: шаг 6, изображение 2 из 2
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  7. iMac Intel 21.5" EMC 2389 Display Replacement: шаг 7, изображение 1 из 2 iMac Intel 21.5" EMC 2389 Display Replacement: шаг 7, изображение 2 из 2
    • The display data cable plug has a wire lock. Disengage the plug's lock by rotating the plastic tab so that it points upward. (It is not a pull tab.)
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  8. iMac Intel 21.5" EMC 2389 Display Replacement: шаг 8, изображение 1 из 2 iMac Intel 21.5" EMC 2389 Display Replacement: шаг 8, изображение 2 из 2
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
  9. iMac Intel 21.5" EMC 2389 Display Replacement: шаг 9, изображение 1 из 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
Заключение
34 участников успешно повторили данное руководство.
6 Комментариев
I damaged the lcd frame (with magnets) and I don't know where to find it. Can you guys help?
It's just the frame with magnets that attaches the lcd screen...
fredericoconchinha - Ответить
hey thanks for this.... i had to swap LCDs due to well known streak/screen fault.
after over 2 years using external display for work, i saw this blog and thought i might try.
the stakes were extremely high (my wife's iMac and no cash to get OOW apple repair, but your help got me through it. super cheers.
NB. i found this other thread most helpful re: the side strips that screw to the LCD panel and the iMac chassis.
iMac LCD Cleanup
rob - Ответить
Hey
where can I buy the LED backlight power cable from step 6
thanks
Swiss - Ответить
I'd like to buy IMAC LCD Model: ME086ZP/A. Where can I buy this item?
Ellen Laserna - Ответить
Hi, is that possible to replace the LCD diaplay by a 4k display?
J.J. JIANG - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 45
За последние 30 дней: 189
За всё время: 67,780
