Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide is an internal prerequisite that should remain unpublished.
Запчасти
Детали не указаны.
  1. If present, remove the pieces of clear tape securing the ambient temperature sensor cable and the left speaker cable to the rear case.
    • If present, remove the pieces of clear tape securing the ambient temperature sensor cable and the left speaker cable to the rear case.
  2. Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
    • Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
  3. Peel the cable retainer off the side of the CPU fan.
    • Peel the cable retainer off the side of the CPU fan.
    • If the tape on the cable retainer loses adhesion, remove the existing foam tape and either use double-sided tape or glue to reattach it to the CPU fan.
    • Remove the CPU fan from the outer case, minding any cables that may get caught.
  4. De-route the left speaker cable from the clips securing it to the outer case.
    • De-route the left speaker cable from the clips securing it to the outer case.
  5. Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer. Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer.
    • Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer.
Заключение
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,725
