Введение
Upgrade your RAM for an instant increase in speed.
Выберете то, что вам нужно
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
Use the sharp tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
Grab the RAM chip by its edges and pull it straight out of its slot.
111 участников успешно повторили данное руководство.
In order for the logic board to come out cleanly, one should remove the RAM at the end of this step.
kevmacmills - Ответить
Definitely! The author should make this as a step in the description (because not everyone reads Comments)
finnik2d - Ответить
Just did this procedure and the RAM must absolutely come out for the logic board to come free later.
matt - Ответить
