Введение
Internal Prereq.
Выберете то, что вам нужно
Pull the hard drive temperature sensor connector toward the top edge of the iMac to disconnect it from its socket on the logic board.
Remove the two 9 mm T10 Torx screws securing the upper hard drive bracket to the outer case.
Slightly rotate the hard drive out of the outer case and lift it up off its mounting pins toward the top edge of the iMac.
Disconnect the SATA data cable and SATA power connector from their respective sockets by pulling each connector away from the hard drive.
