iMac Intel 21.5" EMC 2428 AirPort Card Replacement
Выберете то, что вам нужно
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  1. iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 2, изображение 1 из 2 iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 2, изображение 2 из 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  2. iMac Intel 21.5" EMC 2428 AirPort Card Replacement, Display: шаг 3, изображение 1 из 3 iMac Intel 21.5" EMC 2428 AirPort Card Replacement, Display: шаг 3, изображение 2 из 3 iMac Intel 21.5" EMC 2428 AirPort Card Replacement, Display: шаг 3, изображение 3 из 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  3. iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 4, изображение 1 из 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board. Twisting or pulling the display assembly with the cables attached will damage your iMac.
  4. iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 5, изображение 1 из 2 iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 5, изображение 2 из 2
    • Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
  5. iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 6, изображение 1 из 2 iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 6, изображение 2 из 2
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  6. iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 7, изображение 1 из 3 iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 7, изображение 2 из 3 iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 7, изображение 3 из 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it towards upwards.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  7. iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 8, изображение 1 из 2 iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 8, изображение 2 из 2
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
  8. iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 9, изображение 1 из 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  9. iMac Intel 21.5" EMC 2428 AirPort Card Replacement, AirPort Card: шаг 10, изображение 1 из 2 iMac Intel 21.5" EMC 2428 AirPort Card Replacement, AirPort Card: шаг 10, изображение 2 из 2
    • Use the flat end of a spudger to pry all three AirPort antenna cable connectors up from their sockets on the AirPort card.
    • During reinstallation, connect the cable with no stripes to the socket marked CH0, the cable with one stripe to CH1, and the cable with two stripes to CH2.
  10. iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 11, изображение 1 из 1
    • Remove the single 5.3 mm T6 Torx screw securing the AirPort card to its socket.
  11. iMac Intel 21.5" EMC 2428 AirPort Card Replacement: шаг 12, изображение 1 из 1
    • Pull the AirPort card away from its socket and remove it from the iMac.
Заключение
10 участников успешно повторили данное руководство.
Один комментарий
Inversion de CH / CH inversion :
J'ai constaté deux fois le même problème en changeant le HDD.
J'ai connecté normalement et ça fonctionne.
I have seen the same problem twice by changing the HDD.
I connected normally and it works.
Avant / Before : 0 = CH 2/1 = CH 1/2 = CHO
Après / After : 0 = CH 0/1 = CH 1/2 = CH 2
Cancan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 55
За всё время: 15,539
