Введение
Prereq only.
Выберете то, что вам нужно
Remove the strip of tape securing the GPU thermal sensor cable to the logic board.
Remove the following three screws:
One 4.2 mm T10 Torx screw
Two 5 mm T8 Torx screws
Grab the GPU thermal sensor cable connector and pull it straight up and out of its socket on the logic board.
Lift the GPU heat sink slightly and pull the GPU board out of its socket on the logic board.
Почти готово!
Заключение
