Введение
Prereq only.
Выберете то, что вам нужно
Remove the two 9 mm T10 Torx screws securing the upper hard drive bracket to the outer case.
Slightly rotate the hard drive out of the outer case and lift it up off its mounting pins toward the top edge of the iMac.
Disconnect the SATA data cable and SATA power connector from their respective sockets by pulling each connector away from the hard drive.
Почти готово!
Заключение
