Введение
Prereq-only guide to remove the entire display assembly.
Запчасти
Детали не указаны.
  1. iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: step 1, image 1 of 2 iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: step 1, image 2 of 2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  2. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: step 2, image 1 of 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: step 2, image 2 of 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: step 2, image 3 of 3
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  3. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: step 3, image 1 of 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: step 3, image 2 of 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: step 3, image 3 of 3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
Заключение
Adam O'Camb
Участник с: 11.04.2015
166 213 Репутация
Автор 418 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 49
