Введение
Follow the steps in this guide to remove or replace the heat sink in a 21.5" Retina 4K 2019 iMac.
Some images in this guide use an older iMac, which has minor visual differences. These differences do not affect the repair procedure.
This guide requires you to handle a power supply that contains large capacitors. Unplug the iMac and hold the power button down for at least 10 seconds to help discharge the capacitors. Handle the power supply board by the edges and do not touch surface components.
Выберете то, что вам нужно
With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge, in the stand to stabilize the iMac.
Starting on the left side of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
Use the tool like a pizza cutter—roll it along the gap, cutting the foam adhesive in between the frame and display.
Run the tool up along the left side of the display.
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
Gently twist the plastic card sideways to create a gap between the display and frame.
Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
Gently twist the card upward, slightly increasing the space between the display and frame.
With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
Begin to lift the top of the display up from the frame.
Hold the display with one hand while using your other hand to unplug the display power cable.
Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the logic board.
Lift the display up from the frame and remove it from the iMac.
It may be necessary to slowly lift from one side to peel against the remaining adhesive.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
Two 21 mm screws
One 9 mm screw
One 27 mm screw
Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
Remove the two 7.2 mm T8 Torx screws securing the power supply to the rear enclosure.
Pull the power supply slightly up and out from the rear enclosure.
Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
Slide the power supply to the right to clear the screw posts on the rear enclosure.
Rock the power supply forward and remove it from its recess in the rear enclosure.
To disconnect the cable, squeeze the release clip on the back side of the connector, behind the logic board, and pull the connector straight out.
Use the flat end of a spudger to press the release clip on the side of the AC inlet cable connector inward.
While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
Gently pull the fan cable connector straight out of its socket on the logic board.
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
Remove the 7.3 mm T8 Torx screw securing the hard drive tray to the rear enclosure.
Remove the SATA cable from the clips on the back of the hard drive tray.
Remove the hard drive tray.
Gently pull the left speaker cable straight out of its socket on the logic board.
De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip.
Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables.
Flip up the metal retaining bracket on the FaceTime camera cable connector.
Pull the iSight camera cable straight out of its socket on the logic board.
Remove the two 4.0 mm T5 Torx screws securing the four AirPort/Bluetooth antenna connectors.
Rotate the top of the AirPort/Bluetooth connector bracket away from the logic board, then lift the bracket straight up and remove it.
Use the point of a spudger to pry all four antenna connectors straight up from their sockets and disconnect them from the AirPort/Bluetooth card.
Use a pair of tweezers or your fingers to pull the right speaker cable connector straight down and out of its socket on the logic board.
Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
Push the cable slightly to the right to move it out of the way of the logic board.
Remove the following T8 Torx screws securing the exhaust duct to the rear enclosure:
Two 6.2 mm screws
Two 4.7 mm screws
Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
Use tweezers to gently pull the microphone ribbon cable straight out of its socket.
Remove the four 7.3 mm T8 Torx screws securing the logic board to the rear enclosure.
Tilt the top of the logic board away from the rear enclosure.
As you tilt the logic board, pull the right speaker connector to the right and out of the way of the board.
Lift the logic board straight up and out of the iMac.
Use a USB flash drive and/or ethernet cable to keep the logic board seated correctly while you tighten the screws.
While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
Grasp the hard drive power connector and gently pull it out of its socket on the logic board.
Peel off the four black tamper-evident stickers covering the heat sink mounting screws.
Remove the four T10 screws that secure the heat sink from the backside of the logic board.
Fully loosen the three captive T8 screws securing the heat sink over the GPU.
Remove the two 5.4 mm T8 screws securing the heat pipe to the logic board.
