Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace the circuit board controlling the camera on your iMac.
Выберете то, что вам нужно
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
Disconnect the microphone cable.
Disconnect the camera cable by pulling its connector away from the socket on the camera board.
Use the tip of a spudger to flip up the camera ribbon cable retaining flap.
Use the tip of a spudger to pull the camera ribbon cable away from its socket on the camera board.
In the next step, you will rotate the two black retaining clips (shown in red) away from the camera board to free it from the front bezel.
Use your thumbs to simultaneously rotate both retaining tabs away from the camera board while pushing the board up from either side with your index fingers.
Remove the camera board from the front bezel.
2 участников успешно повторили данное руководство.
