Введение
Use this guide to replace a broken LCD.
Выберете то, что вам нужно
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
Disconnect the microphone cable.
Disconnect the camera cable by pulling its connector away from the socket on the camera board.
Peel the two highlighted EMI shield tabs off the frame of the LCD.
Remove the two T6 Torx screws securing the display data cable to the logic board.
Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
De-route the inverter cable from its location next to the CPU fan.
Remove the eight T8 Torx screws securing the display assembly to the rear case.
Remove the two pieces of tape securing the display data cable to the back of the display.
Squeeze the two retaining arms together and pull the display data cable connector out of its socket.
Remove the large piece of tape covering the inverter cable connector and any tape securing the cable to the inverter board.
Lift the inverter cable connector straight up from its socket on the inverter board.
Remove the two Phillips screws securing the inverter board to the back of the LCD.
Carefully lift the black cover off the inverter board from the side closest to the edge of the LCD.
Disconnect the seven locking connectors from the side of the inverter board.
4 участников успешно повторили данное руководство.
