iMac Intel 24" EMC 2111 Optical Drive Cable Replacement
Выберете то, что вам нужно
    1. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement, Access Door: шаг 1, изображение 1 из 2 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement, Access Door: шаг 1, изображение 2 из 2
      • Loosen the two Phillips screws securing the access door to your iMac.
      • Both screws remain captive within the access door.
      • Remove the access door.
      Спросите у FixBot
      Добавить комментарий
    1. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement, Front Bezel: шаг 2, изображение 1 из 1
      • Remove the following screws along the lower edge of your iMac:
      • Three 6 mm T8 Torx screws
      • One 8 mm T8 Torx screw
      Спросите у FixBot
    2. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 3, изображение 1 из 2 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 3, изображение 2 из 2
      • Lay your iMac stand-side down on a flat surface.
      • To lift the front bezel off the iMac, simultaneously:
      • Use your thumbs to press in the RAM arms and hold the iMac down.
      • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
      • Pull the front bezel up with your index fingers.
      • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
      Спросите у FixBot
    3. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 4, изображение 1 из 3 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 4, изображение 2 из 3 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 4, изображение 3 из 3
      • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
      • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
      • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
      Спросите у FixBot
    4. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 5, изображение 1 из 1
      • If necessary, remove the strip of tape covering the microphone cable connector.
      • The microphone connector is located near the inside of top edge of your iMac.
      Спросите у FixBot
    5. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 6, изображение 1 из 3 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 6, изображение 2 из 3 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 6, изображение 3 из 3
      • Disconnect the microphone cable.
      • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
      • The camera cable connector and socket are delicate and easily bent. Remove with caution.
      Спросите у FixBot
    1. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement, Display Assembly: шаг 7, изображение 1 из 2 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement, Display Assembly: шаг 7, изображение 2 из 2
      • Peel the two highlighted EMI shield tabs off the frame of the LCD.
      Спросите у FixBot
    2. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 8, изображение 1 из 1
      • Remove the two T6 Torx screws securing the display data cable to the logic board.
      Спросите у FixBot
    3. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 9, изображение 1 из 1
      • Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
      Спросите у FixBot
    4. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 10, изображение 1 из 2 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 10, изображение 2 из 2
      • Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
      • De-route the inverter cable from its location next to the CPU fan.
      Спросите у FixBot
    5. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 11, изображение 1 из 1
      • Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
      • Remove the eight T8 Torx screws securing the display assembly to the rear case.
      • It is helpful to use a thin magnetized screwdriver to remove these screws.
      Спросите у FixBot
    6. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 12, изображение 1 из 1
      • Remove the display assembly from the iMac.
      Спросите у FixBot
    1. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement, Optical Drive: шаг 13, изображение 1 из 1
      • Remove the strip of tape covering the optical drive cable connector.
      Спросите у FixBot
    2. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 14, изображение 1 из 2 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 14, изображение 2 из 2
      • Gently pull the cable retainer on the optical drive cable ZIF socket toward the right side of the iMac.
      • The retainer should move about 1 mm and stop. Do not attempt to remove the retainer.
      Спросите у FixBot
    3. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 15, изображение 1 из 1
      • Pull the optical drive ribbon cable out of its socket, being careful not to rip it in the process.
      Спросите у FixBot
    4. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 16, изображение 1 из 1
      • Pull the optical drive thermal sensor connector toward the right side of the iMac to disconnect it from the logic board.
      Спросите у FixBot
    5. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 17, изображение 1 из 1
      • Peel off the strip of EMI tape attaching the right side of the optical drive to the rear case.
      Спросите у FixBot
    6. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 18, изображение 1 из 1
      • Push down on the optical drive bracket retaining clip while pulling the top edge of the optical drive away from the rear case.
      Спросите у FixBot
    7. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 19, изображение 1 из 2 iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 19, изображение 2 из 2
      • Rotate the optical drive slightly toward the bottom edge of the iMac while pulling it away from the rear case to release the lower retaining clip.
      • Pull the optical drive away from the right side of the rear case and remove it from the iMac.
      Спросите у FixBot
    1. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement, Optical Drive Cable: шаг 20, изображение 1 из 1
      • Remove the two T6 Torx screws securing the optical drive cable to the optical drive.
      Спросите у FixBot
    2. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 21, изображение 1 из 1
      • Insert the flat end of a spudger into the gap between the optical drive cable connector and the optical drive.
      • Twist the spudger to separate the connector from the optical drive.
      • Repeat this process for both sides of the connector.
      Спросите у FixBot
    3. iMac Intel 24" EMC 2111 Optical Drive Cable Replacement: шаг 22, изображение 1 из 1
      • Pull the optical drive cable connector away from the optical drive.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 22
За последние 30 дней: 66
За всё время: 3,324
