Введение
Prereq only
Выберете то, что вам нужно
Disconnect the thermal sensor, SATA power, and SATA data cables by pulling their connectors away from the sockets on the hard drive.
Remove the two T10 Torx screws securing the upper hard drive bracket to the outer case.
Slightly rotate the hard drive away from the outer case.
Lift the hard drive off its two lower positioning pins and remove it from the outer case.
Remove the two T8 Torx screws securing the upper bracket to the hard drive.
Remove the upper bracket from the hard drive.
Carefully peel off the piece of EMI foam attached to the front of the hard drive.
