iMac Intel 27" EMC 2429 Graphics Card, CPU, Hard Drive, Ram Upgrade
Выберете то, что вам нужно
    • First Start by unplugging all cables from your iMac and setting up a workstation.
    • You will need a large workstation to hold the iMac and it's parts.
    Спросите у FixBot
    Добавить комментарий
  1. Инструмент, используемый на этом этапе:
    Heavy-Duty Suction Cups (Pair)
    $16.95
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
    Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Electronic Cartel
Участник с: 12/23/23
170 Репутация
1 руководство автора
7 Комментарии к руководству
Where is the rest of this guide?
Andrew Gannon - Ответить Поделиться
Obviously not following this guide, I opened my iMac that had full graphics failure, uninstalled the GPU-card, cleaned it, baked it in the oven to soften the solder and let the chip reattach itself, added new conductive paste, reinstalled it and it worked again.
I can't remember the temperatures, but there are tutorials to be found.
Bernhard - Ответить Поделиться
How long did your fix last?
I tried this heating of the GPU on a MacBook Pro 15" 2011 and it help up not even two months.
Colonel Task - Ответить Поделиться
Non è una guida. Manca tutto!
Giacomo Santerini - Ответить Поделиться
This guide only covers removal of the outer glass and LCD display. Where are the rest of the steps?
Daniel O'Leary - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 43
За последние 30 дней: 206
За всё время: 8,552
