iMac Intel 27" EMC 2429 LED Driver Board Replacement
Выберете то, что вам нужно
  1. iMac Intel 27" EMC 2429 LED Driver Board Replacement, Glass Panel: шаг 1, изображение 1 из 3 iMac Intel 27" EMC 2429 LED Driver Board Replacement, Glass Panel: шаг 1, изображение 2 из 3 iMac Intel 27" EMC 2429 LED Driver Board Replacement, Glass Panel: шаг 1, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Купить
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
  2. iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 2, изображение 1 из 3 iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 2, изображение 2 из 3 iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 2, изображение 3 из 3
    • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
    • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 27" EMC 2429 LED Driver Board Replacement, Display: шаг 3, изображение 1 из 1
    • Remove the eight T10 Torx screws securing the LCD to the outer case.
    • Be careful not to touch the display as the oil from your fingers may leave a residue that can be difficult to remove.
    • If necessary, peel the EMI gaskets located near the top center edge of the display assembly.
  4. iMac Intel 27" EMC 2429 LED Driver Board Replacement, Display: шаг 4, изображение 1 из 3 iMac Intel 27" EMC 2429 LED Driver Board Replacement, Display: шаг 4, изображение 2 из 3 iMac Intel 27" EMC 2429 LED Driver Board Replacement, Display: шаг 4, изображение 3 из 3
    • Carefully lay the iMac stand-side down on a flat surface.
    • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the first picture, we made one out of a bent paperclip. A pair of angled tweezers can also work well.
    • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
    • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
    • Raise and hold the display high enough to access the cables.
    • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
  5. iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 5, изображение 1 из 1
    • Disconnect the vertical sync cable in the upper left corner of the screen. Use the tip of a spudger to push on the connector's side tabs and gently walk it out of its socket.
  6. iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 6, изображение 1 из 1
    • This step brings your hands close to the exposed rear of the power supply. To avoid a high-voltage shock from the many large capacitors attached to the board, do NOT touch the rear of the power supply.
    • Disconnect the LED backlight driver cable with your hand by pressing the tab down and sliding it towards the bottom of the display.
  7. iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 7, изображение 1 из 2 iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 7, изображение 2 из 2
    • Pull the black tab straight up to disconnect the latch on the display data cable ZIF connector.
    • Do not pull up too hard or you will damage the connector and socket.
    • Continue to pull the black tab up toward the top of the device, to detach the display data cable.
  8. iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 8, изображение 1 из 1
    • Use the tip of a spudger to disconnect the display power cable next to the display data cable.
  9. iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 9, изображение 1 из 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the iMac case.
  10. iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 10, изображение 1 из 1
    • Lay the display face down on a flat, soft surface.
    • If you are replacing the display panel, you will need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
    • If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
    • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
    • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
  11. iMac Intel 27" EMC 2429 LED Driver Board Replacement, LED Driver Board: шаг 11, изображение 1 из 1
    • Remove the four T10 Torx screws securing the LED driver board to the outer case.
  12. iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 12, изображение 1 из 2 iMac Intel 27" EMC 2429 LED Driver Board Replacement: шаг 12, изображение 2 из 2
    • Lift the LED driver board out of its recess in the outer case, minding the DC-In cable still attaching it to the power supply.
    • Disconnect the DC-In cable by depressing the locking mechanism while pulling the connector away from its socket on the LED driver board.
Заключение
16 участников успешно повторили данное руководство.
Phillip Takahashi
Участник с: 08/22/11
86 686 Репутация
Автор 87 руководств
9 Комментариев
Hello - I have this same issue and tried to complete this repair, but the VSync connector on the new LED Driver Board is different. Has anyone had this issue? Know of a reason why? Any help would be appreciated.
Thanks
Chris James - Ответить
I have found two different inverter boards in the 27” 2011 iMacs. One, like shown here, has a 4 pin connector on the top edge that a small connector with 2 wires coming directly from the LCD panel plugs into. The other has an 8 pin connector with a cable about 16” long that goes from that connector to the 8 pin connector on the logic board labeled BLC_ACDC. I’ve come across this configuration 2 or 3 times, out of 40+ iMacs I’ve refurbished.
The inverter board with 8 pins has a part number of V267-E02HF and they sometimes show up on eBay. The cable has a part number of 593-1435 and they’re impossible to find.
tpluth -
With the V267-E02 inverter installed, I have seen panel LM270WQ1 (SD)(E5) used instead of the normal LM270WQ1 (SD)(E3).
tpluth -
Is there a chance the cable is bad? I just replaced my logic board and now the PC is up and running normal but the screen is dark, I see the desktop if I shine a light on the screen.
How can we test if possibly the cable is broken?
Pawel Pluta - Ответить
Please note that the part for this EMC number os 604, and not 601
Sonnicham - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 14
За последние 30 дней: 73
За всё время: 34,311
