Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
prerequisite for logic board, heat sink, and CPU
Выберете то, что вам нужно
Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
Remove the spring plate from behind the CPU heat sink.
Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
