Введение
If your iMac was configured with a solid state drive or Fusion Drive it includes a blade SSD on the back of the logic board. Use this guide to access and remove the SSD.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:iMac Intel 27" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
Would a heat gun make this step easier? Or damage the iMac?
A heat gun wouldn’t help you here as you still need to cut though the adhesive. You also risk damaging the display with the excessive heat.
Dan -
Removing the original adhesive is easier than removing newly applied adhesive (e.g., if you have to reopen iMac). If you should happen to need to reopen the iMac, please use extreme caution and highly consider my suggestions below.
When using the pizza cutter tool, do the first few steps in reverse starting with step 8. Starting on the left side is better since this is where the adhesive is narrowest. The right side has two antennas and the top right has one, see the pictures for step 18-21, they are the brass colored metal rectangles near the edges. The adhesive on these pieces are wider and therefore have more holding power. The thickness of the pizza cutter tool is enough to crack the glass.
Continuing from my previous comment. To remove the adhesive on the right side you’ll need to create a very slight gap to give the pizza cutter some more room. Do this by cutting the adhesive on the left side up and around to the camera. Before attempting to cut the right side. Carefully slide the plastic cards (I purchased two sets) to ensure the adhesive on the left top and side is completely free. Now slowly move towards the right side. After every inch or two of removing new adhesive, slide the card over to create this slight gap. Be careful to not move the card too close to where the adhesive has not been cut. You want to create a very slight gap without creating too much pressure. Use extra caution with approaching the areas where the antenna are since the adhesive is stronger here and will need some additional cutting. Follow this approach all the way around the right side. Be careful to not create too much pressure at any one time. Good Luck!.
I can confirm with Walter - trying to remove freshly applied adhesive is WAAAAY harder! My pizza cutter didn’t work correctly (the circle became a rectangle!) and I ended up with a small crack on the left of my screen. Dang it!
I would highly, highly, highly recommend AGAINST doing this at home. I followed these instructions to a T, and still somehow managed to have the screen not be able to turn on after the hard drive replacement. Then, once you’ve opened your Mac yourself, Apple will refuse to fix anything on the computer, and even other third party, Apple-authorized repair facility will refuse to repair it for you, and you will have to locate a non-authorized Apple repair facility. There, I am having to pay ~$600 to fix things that got screwed up, even though I followed the instructions here to a T, step by step, and did everything slowly and methodically.
Beware, if you’ve never done this before, that be locked out of ever being able to use an Apple repair facility, or Apple-authorized repair facility, if you mess things up here now.
I performed this on a Late 2015 iMac and there weren’t any significant differences to these steps, but I did find the repair to be nerve-wracking. My model cost nearly $3,000 and about 10 steps into this guide (which I did fully read ahead of time) I was thinking, “what have I got myself into?” But I didn’t rush and happily I’m typing this on my repaired iMac! I found a video from OWC that was more useful than the photos in this guide for certain steps: https://vimeo.com/139364064
Don’t know if you are still around, but THANK YOU for posting this video! The video made it seem SO NOT SCARY and, in conjunction with the photos and comments and tips on this guide, was a lifesaver. Big thumbs up.
First impressions so far: yes it can be a bit nerve wrecking if it is your first time doing this sort of thing and even with lots of experience with a 2011 model it’s still a bit unsettling haha (nervous laughter).
What I recommend: use a guitar pick to start cutting the glue. You’ll need a bit of pressure so do just the tip.
Once you’ve done the whole perimeter (minus bottom) do it again but now it should be easier to go deeper so go very slow and careful. Then get the old suction cups used to open older models and start lifting the display very carefully to see where it’s still glued and cut those as well.
Then you should be done and now the real fun begins! :D
It’s ridiculous. Apple should pay for doing this. Like glue parts together to block a repair / make difficult. I smashed my iMac. FU Apple. Seriously, every product I owned had hardware issues. For example, bad solder joints. Never again Apple. I’m happy with Windows and in 2018 / 2019 there are many other manufacturers with high quality stuff. Apple is dying, if they do not change …
NOTE: I followed every step word for word, but the adhesive strips supplied are as bad as double sided tape. Within 48hours the screen had slipped off and cracked. Now I need to fork out for a new screen and try again.
Not sure what to try next time with strips? Perhaps a bit of glue to help hold it??
Where do i get the “iMac Opening Tool?” its neither in the list of tools nor could i find it on the tool page.
Hi @snappadoodle! The opening tool is included in the adhesive kit included in the tool list, but you can purchase it separately here.
After disconnecting the power cord and before cutting the panel adhesive, push and hold the power button for 10 seconds. This will discharge the power supply capacitors. In case you accidentally touch the solder joints on the board, you won't be shocked and drop the panel.
Bottom line: This repair seems to have worked (so far no more intermittent shut-downs). Thanks iFixit!
As a novice who fully expected to destroy the display or worse, I make the following recommendations: (1) Before you start, read the steps several (many) times; visualize doing them and imagine how things could go wrong; (2) Read all the comments—there were some really helpful tips—like simply displacing the left speaker rather than fully removing it; (3) Get the recommended tools*; and (4) take your time—if you start to feel frustrated—seriously, stop and take a calming breath. Time is your friend. Failure is not an option.
*I would add a 3-prong parts puller to the tool list—it’s great for pulling and starting loose screws so you don’t drop them down into the chassis like I did. It’s also great for retrieving the screws you’ve dropped into the chassis.
Hi brad, what exactly did you repair to stop the shutdowns? I’m having the same issue
merinian -
Merinian: I replaced the power supply and it’s still working fine at this late date. No more intermittent shut-downs. Fingers still crossed!
Thank you very much for the instructive tutorial. I just successfully replaced the hard drive on my 2012 iMac 27. I used a disposable surgical scalpel 15 blade, and locked the blade extending 9 mm from the scalpel shaft using office tape. I used regular double sided tape to reattach the screen. I cut the strips using the scalpel. I have no previous computer experience and this is the first time I replaced a computer part. This was easy and fun.
Filip Dolatowski - Friday 11th Dec 2020
You are very lucky! I’ve had three systems come in which someone did the exact same thing! All three cut the display ribbon cables. Please don’t use surgical knifes or any other knife! Use the proper tool the special pizza cutter wheel designed for the task.
You likely spent more on the knifes than what the wheel cost with the correct tapes. You make the next time doubly hard to open not using the correct tapes! Hows the built in microphone? You may have messed it up.
Dan -
Thank you very much for the tutorial. You are the best!
After reading all the post here I almost gave up doing this on my own. But I did it anyway and was succesful. I would recommend everyone to use the rollcutter. There is no risk of harming the screen if you use it. And in my case it was enough to open the imac. If you do not harm the screen connector or the screen the biggest part is done. It gets easier once you`ve stacked your screen somewhere safe. The parts inside are mostely not as delicate as the heavy and expensive screen!
Take your time and work carefully. It is definitely doable!
I found the cutter tool that came with my kit to work just fine. The wheel is extremely thin and I had no problem inserting the wheel to begin cutting. I follow the guide for the most part but took my time and use the cutting wheel slowly and then repeated the process a few times. Once I was able to pry the screen back about an inch I used the other end of the tool to cut additional adhesive that was still clinging to the body of the iMac and the screen. Having just replaced the power supply, and having my iMac running again, I do not think I will use the adhesive strips to reattach the screen. The screen fit back in place no problem which I did to test my Mac. Because the iMac screen sits at an angle I am quite comfortable that the screen is not gonna fall off. Also while having a screen off I was able to clean the inside of the Mac of dust buildup. I think I will only use the adhesive strips down the road if I’m gonna sell the Mac, which means I can give it a good clean before securing the screen.
If the screen falls off (which it will do!) it will damage the parts which would be a lot more expensive! PLEASE get the correct tapes and properly mount the screen back on.
Think of it this way how many people have shot them selves with a gun not realizing it was loaded or set to go off!
Dan -
I think Dan is right as I decided it best to complete the process with the adhesive tapes to secure the screen. I just took some time to do a complete clean of the interior before sealing the display.
Ordered the full kit to replace my busted 3TB disc hard drive. All the tools work and are excellent. These pictorial and instructional install videos are complete, easy to use, and have good imagery. The 2TB SSD installed exactly as depicted. I used some 3M double sided automotive emblem tape to stick adapter to iMac case, no probs there. The adhesive strips also worked fine and stick firmly. Screen is solidly mounted, no falling out here. IFixit is awesome and this kit saved my over $1200 in getting another iMac. Highly recommended.
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
Run the tool up along the left side of the display.
In my experience the cutter also worked very well for cutting the original adhesive. Unfortunately when I was reinstalling the display with the new adhesive strips, somehow the display power connector came loose. I had to open the display a second time and the cutter was not as effective against the new adhesive. I managed to break the cutter tool plastic wheel and cause a few small cracks in the edge of the displays glass as I worked! Be careful and go slowly!
The cutting tool worked great until I accidentally twisted it a bit while rounding a corner. A chunk of the wheel snapped off, making the rest of the job quite a bit more challenging. Just make sure you are keeping the tool directly parallel with the screen.
I concur, opening the screen a 2nd time is considerably more difficult because the adhesive strips are thinner than the original, which makes getting the cutting tool inserted much more difficult….as a result unknowingly I elongated a small crack to a much longer crack and somehow, the LCD now has a wide grey strip from top to bottom….The first time opening was easy, second time resulted in a ruined screen.. The cost of. a replacement LCD is the same has replacing the entire computer….I would recommend anyone attempting to remove the screen for any reason, do not use the aftermarket adhesive strips if you ever intend to open it up; again, or cut the strips much shorter, or possibly use a few pieces of scotch tape or similar to hold the screen in place….since the screen tilts back, this should not be a problem…Good luck…
Cut the adhesive along the top left of the display.
The pizza cutter will sink in all the way to the tool handle when the adhesive is full cut, but don’t feel you have to do this in one motion. Some parts cut easier and some require a lot (like 20x) of gentle back and forth.
Continue along the top of the display.
I measured a depth several positions.
- About 6 centimeters near iSight Camera center, you must no use iMac opening tool, because iSight element exists.
- iMac opening tool has a 9mm radius, so it may break iSight camera element.
- Making a plastic card stacking 2 or 3 to 3mm, under the iMac opening tool, that makes inserting a gap 5~6mm like below.
@. iMac opening tool
====== plastic card3 (credit card 1mm)
====== plastic card2 (1mm)
====== platic card1. (1mm)
———————————————— isight camera element (total 5~6cm) ————
In my case, i got a display problem where lcd display yellow connector was torn without care.
Be helpful.
Finish pushing the opening tool to the bottom of the right side of the display.
I didn’t have the fancy cutter or cards. So I used my actual pizza cutter. Followed directions just the same, and it easily cut through the adhesive w/o issues or marring the surfaces. Actually used it to rock back and forth to lift the screen. It’s all about taking your time. I rolled it back and further until cut thru. The 3/8 to 1/4 inch is right, but the screen framing actually prevents further depth unless you force it further. The adhesive actually protected the glass while cutting thru, so no damage. Great instructions, but where to get the replacement adhesive to reinstall?? Should be four independent strips.
You are very lucky you didn't cut to deep! The plastic cutter that's in the kit is the only thing I would use. Spending a few bucks on a tool is a lot cheaper than $500 for a new display!
Please don't use a real pizza cutter!
Dan -
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Set the iMac face-up on a table.
Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
I actually DESTROYED my display (black vertical strips) by pushing the card in a bit TOO DEEP. So it is REALLY important to insert the card only a bit (1-2mm) more than the cutter wheel, in particular at the top side, where many flat cables connect the panel with the PCB. These can be damaged very easily!
Same thing with me…. Pushed cards to far…. new panel needed…€600…..
i think ifixit needs to place a bigger caveat, as I have missed it the first time
i successfully upgraded two imacs. one opened with ifixit pizza knife and another with a regular paper knife. however, when i had to open the first one once again i broke its screen glass. it seems ifixit adhesive strips are too strong. next time i’ll try to use heater to weaken glue tension.
I broke one too. And even if you think you did it correctly, you’ll not be able to see where you might have gone too far. You would think it’s very protected behind that metal plate, but no. Take special care with this offence to “right to repair” This should have been designed WAY better. I mean replacing a hardrive that is very likely to fail over the course of time, or even a simple desire to upgrade to an ssd!.
Bummer
HINT: If you turn the card and use the blue part of it, then you can avoid going to deep: no further then the blue part …
On the cards I got with my iFixit kit, the blue part was way bigger than 9.5mm — closer to 20mm!
I made a line 9mm from the edge of each of my cards and used that as a guide.
I’m thinking I might just use vinyl tape to keep the screen in place for at least a little while after an upgrade. The extra strength of the replacement tape sounds scary.
I wrapped two layers of vinyl electrical tape around the short side of an old gift card 3/8” from the edge. This “stop" prevented the card from going in too far. The card really helps to break the panel free.
This is a good tip!
Great idea! Wish I had read this before doing it. My less then optimal solution was to draw lines 3/8” around the cards, not as safe as your fix, but fast.
surely the card should have been designed such not to go further than certain distance with a barrier band.
The cards don’t have any means to control the depth, its your skills which control it. Its no different from how you use a knife to cut your chicken up when you serve it for dinner.
Dan -
The pizza roller tool is enough to cut through the adhesive. You dont need to cut in a lot further. So the cards are really not necessary.
No problems. I used two old credit cards and marked out a line using permanent marker so it was at the same depth as stipulated on this page. I even pushed it in a little deeper and no issues.
Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
My children tend to collect cards like this from hotels, Disneyland, old IDs, iTunes cards, gift cards etc. They came in handy for this step. After wedging in the first card into the left corner, I wedged the left corner, then added cards along the bottom edge. Finally I continued to push in additional cards to existing cards and found that this created a smooth even pressure along the display top. At 2-3 card-thickness the last of the adhesive let go, gentle as a baby.
Slide the card toward the center of the display, to cut any remaining adhesive.
Put the card into the corner again and let it stay there to keep the adhesive from resettling.
Insert a second card into the gap between the display and frame in the top left corner.
Gently twist the card, slightly increasing the space between the display and frame.
Slide the plastic card toward the center, again stopping just before the iSight camera.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
I would recommend using suction cups at this stage to lift the display.
I would strongly recommend using suction cups
Agreed about the suction cups. An extra pair of hands might be good here as well.
The stickiest location on my iMac was the mid-to-lower section of the right side. There are a couple of thicker areas that needed attention from the plastic cards.
WARNING!!! This is where you can crack you screen. TAKE YOUR TIME! Everything work fine for me because I took my time. I was very shocked at how fragile the screen is. It does have a small amount of flex but don’t push your luck. There were two things that made this easy for me #1 Once you have used the cutting wheel to your best judgement to cut the adhesive, start using the iFixIt plastic cards as spacers and space them evenly around the screen. I used 10 individual cards of and gently moved them up and down at each section two at a time. Once I started having less resistance, I combined 2(i.e. 5 sets total) cards evenly space to allow for move rigid and stronger movement to separate the screen. This really helped me to free up more adhesive. #2 before lifting the screen up fully, use tweezers to pull the adhesive like a string from around the entire monitor. This will make lifting the screen much easier since all adhesive will be removed. Finally when lifting the screen use the cards with your hands under them.
Would any of you consider the possibility of heating the glass with a hot-air fan before starting the process? In that way, the adhesive would let the screen go easier, I think.
The type of tape has a lot to do with it. If the original tapes are still present then the pizza tool slices through the thin foam core of the tape so heating is not needed. If on the other hand someone replaced the tapes with just regular double sided tapes then there is no foam core to split and there is a sizable risk the display will get damaged in the process of taking it off. So sure in this case a bit of heat might help, just be aware the LCD panel area is quite close to the edge along the top three sides so you also have the risk of dating it from over heating!
Dan -
If not for iFixit tuts and tools, no way I could do this. iMac 27" takes the prize as the worst design ever for upgrades/maintenance, what were they smoking when they designed it like this?
I have always believed that a properly placed screw can be a beautiful thing. A few decorative, but functional, screws placed in the back of the iMac case to attach the screen would be awesome, but this method is anything but beautiful and borders on insane.
While holding the display up with one hand, use the other to unplug the display power cable.
Mark all cable connectors with a spot of white correction fluid before removal. This will remove the risk, when reinserting them later, of getting them the wrong way round. Yes - I know they will only plug in one way round, but it does make life easier if you are not in perfect lighting!
At this step, if you mess up anything with these 2 cables, especially when plugging them back in, even if you think you’re following the instructions here to a T, then you’re screwed.
Quote - "Beware, if you’ve never done this before, that be locked out of ever being able to use an Apple repair facility, or Apple-authorized repair facility" You cannot be serious can you? So because someone attempted to repair their own Apple device that they OWN, you are saying that they may/will be locked out of using any Apple repair service again? Ridiculous claim sorry.
The display cable, the wider one, has a lock on it , usually a plastic tape lift tab to release it, once thats flipped it should come out fairly easily, if your experiencing resistance and the cable isn’t coming out then check for this lock/latch, the power cable just pulls out, just don’t rush it everything should go fine, fairly easy to do with the end result a working iMac
Is it possible to replace the power cable if its damaged? I can’t seem to find anything about this.
After finishing my hard drive replacement I reconnected these connectors to test my display before using new adhesive. Everything was working beautifully. But then when I applied the new adhesive and went to seal the display on for good - the display power cable somehow became disconnected! I had to reopen the Mac for a second time which was far more difficult with new adhesive. When reinstalling double and triple check that the cables are securely inserted before the final seal. Sounds obvious but it’s quite the annoyance if something goes wrong at this point.
Very difficult to work with these connectors.
Power cable very difficult to unplug - data cable veeeeery difficult to plug in.
I noticed that working with the iMac positioned vertically (and with a proper support for inclination) makes this step slightly easier…
Interesting comments.. personally, I didn’t find the cables particularly difficult to detach and reattach. You do have to be patient and gentle. Personally, I found that a rolled up beach towel gently wedged between the unit and back of the display helped keep the glass up. Also, a small flashlight can be helpful to see the cables and connectors if you’re lighting isn’t perfect.
I’d agree to John - not overly difficult. My workaround was to prep the screen for re-installation and then place it in front of the standing machine. The cables are long and flexible enough to be put in place even in this state. You can easily attach the cables and continue with fixing the screen to the housing.
I would not recommend doing this step as pictured. The cable you are removing has little tabs on the wide side that can be depressed inwards towards the center of the connector, releasing the cable. If you just grab the cable as pictured and yank it out, without depressing the side tabs, you are likely to damage something. Don’t pull on the wires, use your fingernails at the connector to squeeze the very small little tabs inward to release the cable from the connector.
I agree with maccentric. DO NOT just pull the power cable. Use your fingernail or spudger and gently press the tiny notch inward and towards you gently and one side will disengage. Do the same for the other side and it will slide right out. The notches just have enough edge to catch your nail or spudger. Using your nail is better as you can better feel when you have caught the edge and can feel the cable move.
I lifted the display a few inches up and propped it open in the middle using my iPhone in portrait mode with its torch on. Did the job nicely:
Flip up the metal retaining bracket on the display data cable.
Disconnect the display data cable.
I replaced HDD to SSD and assembled parts again. When I boot up the iMac, I found black lines on display (looks partly not broken).
I searched Internet, and some says graphic card problem, but I didn't touch anything but cable to lift up.
Could the damaged display data cable cause this situation? I hope I could fix this by just replacing the cables..
Sorry, Black lines is a damaged display assembly ;-{ In the process of removing it you either pushed the tool into deep or you torqued the glass severing the tiny wire traces.
Dan -
Same trouble here, is it cable trouble or connector trouble?
Sorry damaged display
Dan -
I think whenever words like "...is a delicate connection that can be broken. Be sure to pull the [cable in a certain direction] ANYTIME.... It is worth either a closeup or 2, maybe one with annotations or insertion directions and maybe a motion direction arrow with the something like and 'X' char or a circle division slash over the wrong one.
I agree! +1
Yes, John is absolutely correct on this one. I damaged the display cable trying to get it back in. A close up would have helped and now my computer might have actually been fixed.
[|There are 2 cables to disconnect on my Mac (?). Also, I don’t see a metal retaining bracket. I can take a picture, but cannot attach. I got the glass loose with no problem, but am worried about damaging the cables]
Hi Jim! You can go to our Answers Forum to post some better images of your situation!
First: During reassembly, I highly recommend you connect these cables and do a test boot BEFORE you remove the protective tape on the adhesive strips. That way you can fix any issues(like a damaged cable) if something is not right and you have not re-glued the screen back down which will cause a problem. If you have a second person and everything is working after test boot, you can just leave the cables connected, lift the bottom of the screen and have 2nd person pull the protective tape on the adhesive strips and you can set the screen in place. Second I damaged the video data cable during reassembly on my late 2015 iMac- I did not get the connector straight and I damaged the wires on the cable. I recommend you have someone else hold the screen while you attach the cables - they are fragile. Luckily, the data cable was easily replaced for only about $20. If you must do this by yourself, just be careful I highly recommend have 2 people at this step during reassembly.
At least on my “late 2013” model, the smaller display cable connector has tiny, tiny clips on the outside edges. These must be squeezed to unlatch it. Don't pull on the cable itself or the wires can be pulled out. Even with my small fingers, it was hard to grip the clips. When reconnecting, the connector will lightly snap into place.
I managed this step without any problems, but I had my wife hold the screen up while I disconnected/connected the cables. I STRONGLY encourage another pair of hands here so you can focus your full attention on being ultra careful with the cables.
On the 2015 there are 2 cables.
1. Once the display is loose use the Mac foam block sold from Ifixit to keep the display from rocking to hold open the glass
2. Blow out dust with canned air
3. Get a flash light and small flat edged screw driver
4. Use the screw driver to slow pry loose the connector from the socket by gently inserting it in the gap on the left and then on the right slowly easing the connector from the socket towards the top of the glass
5. The more center connector has a pull tape and a wire loop. Lift pull tape and the wire loop will raise up.
6. Pull the wire loop towards the top of the glass to slide out the connector from its socket
Good instructions except for the screwdriver - try and use a plastic spudger instead ! Also, getting a headworn LED light makes life a bit easier.
Have a late 2013 model and went to do the SSD upgrade. When going to remove the display we cracked the bottom left corner of the glass (just the glass frame part - not part of the screen that displays anything). We were also having difficulty putting re-attaching the display flex cable. Whenever we finally went to test it before re-sealing the screen back on with new adhesive it would sound like it is turning on as it makes boot-up noises and the fans start running, but the screen would just remain black. Just wondering if the crack in the bottom left-hand side of the glass/display would have damaged a part of the display assembly or if it would be more likely that we just damaged the display flex cable (which can be replaced for $26)?
Did you get to the bottom.of this?
does anybody know how the Display Cabel pin assignment is? I want to try if I can attach the Panel to another grafic card
I’ve completed the upgrade to SSD, but while restarting my screen remains black. As if no connected.
I assume I broke the sensitive connector.
—> how to order a spare?
Did you get to the bottom of this?.
No! Apple loves to mess us up!
Dan -
The panels are different since technology progresses at a rapid pace and Apple does like to be on bleeding edge of things. When they do a manufacturing run of screens, there will be a few years that will have the same screen. I believe 2017 is when they introduced the higher resolution panels. Everything from 2012 late to 2015 should be the same though.
That display cable connector is common to many Macs of the 2012 era. I’ve destroyed 2 in 38 years of servicing all types of computer equipment.
As stated, there is a latch on this connector. If you put any incorrect force on the cable or connector during disassembly or reassembly, you will break the cable and possibly the connector. The cables can be purchased online and the video connector on the display is exactly the same.
I repeat, if you pull out on the video cable after it has been unlatched instead of parallel to the logic board, YOU WILL BREAK IT.
Lift the display up to a near-vertical position.
Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
Thanks Stef, this has saved me! Simple yet very effective.
Yep, I cracked the lower corner of the display as well. I failed to work the adhesive enough to loosen it sufficiently. Be careful, I just had to buy my customer another screen!
There seems to be missing a step or two. As I was removing the old display, there are two wires that need to get transferred to the new replacement display. There is not note about these two wires located at the top of the display. The 1.128-inch ribbon cable and then this other 4-inch long, two-wire cable that goes to a very small circuit board that is 1/4 by 3/8 of an inch and seems to be adhered to the panel.I have not been able to get this cable off the old display. There is a port for it on the replacement display.
Note: When ordering this screen, and plastic cards as noted tools, ifixit.com did not list the pizza cutter or the new replacement adhesive strips. So now I’m not sure how to get the new one on and secure.
Are you sure your trying to remove a late 2013 model A1419 display assembly?
robert -
The adhesive strip along the bottom is designed with a pull tab on each outer end. Rather than lever and pull the screen simply carefully pull the tab which removes that half of the lower adhesive strip and frees up the screen.
Niemals den unteren Klebestreifen mit einem scharfen Gegenstand wie Rasierklinge oder so versuchen zu trennen, davon geht die Beschichtung des Displays kaputt und man hat hässliche Streifen unten hinter dem Glas. Stattdessen lieber versuchen, das Display nach oben zu klappen und abzuziehen.
translation from Bas Ti because this is very important:
Never try to separate the bottom adhesive strip with a sharp object such as a razor blade or something, the coating on the display will break and you will have ugly strips at the bottom behind the glass. Instead, try to flip up and pull off the display.
If you are just replacing the hard drive, I have found that it is quite possible to do while leaving the screen connected, making the process much easier. The amount you need to tilt the screen to access the little pull tabs at the bottom to release the screen is also sufficient to access the drive. I remove the drive while the iMac is upright. I also heat up the bottom of the screen to soften the glue and to help with the possibility of the glass cracking while doing this step.
Very dangerous! You’ll stress the cables and the logic board connectors.
Dan -
I meant that you can leave the bottom strip of adhesive attached; you still need to disconnect the 2 cables.
As mentioned before you can pull out the lower adhesive strip. Dont cut it or move the display up and down. This is even more dangerous. On the lower side of mac where the display glass ends is a offset. When moving the display up and down you might crack it over that offset.
When removing the adhesive from the top of the screen, be sure to start at the iSight camera location (= in the middle). If you start at an upper egde of the glass (side doesn’t matter) towards the middle, you risk removing the black background foil from the screen, which will result in ugly stripes behind the glass.
If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
Would have been helpful to box the same red area when using the plastic card to separate the glue. Since the red blocked picture is inverted, if someone doesn't pay close attention it may not be obvious that the area of concern is at the right top of the graphic pictures in which the plastic card use is being demonstrated..
you don't need to cut the bottom part as the bottom tape is stuck on each side and you can easily pull it out
[|I opened up my iMac and there’s no HDD or SSD in that spot. its just empty.]
You probably had just an SSD installed and no HD, which is on the opposite side of the motherboard (and quite a bit more work to access).
Please update the picture to include the RED BOXED IN AREA that you refer to on all three pictures in this step. I have had a few zaps from these supplies and it is not pleasant.
J’ai réussi à intervenir dans l’iMac sans décoller l’ensemble de l’écran. Je l’ai ouvert en laissant la dernière partie collée (vers le logo Apple) et qui sert comme une charnière. Bien calé et assuré l’écran n’a pas bougé et j’ai pu changer mon disque dur facilement. Le grand avantage et d’avoir l’écran toute suite juste quand on le recolle par la suite.
Well, I of course touched a soldering point in the red area as my hand slipped. I heard and felt a tiny “click” and after replacing the HDD with SSD etc I can not power the iMac up anymore. Not a sign of life :-( I suppose I broke the power supply. Can someone confirm? Or could something else have broken too?
I took my time and pulled both tabs slowly gently. Easily removed and glass came right off.
Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
You really should be using film handling or surgical type gloves to handle the screen to minimise finger grease on any of it. Even if it’s possible to clean most of it off, it can be corrosive over time.
Use a large suction cup and latex gloves for this:
I think iFixIt should have mentioned this step might be safer using a suction cup as mentioned by Philip.⏎
I thought following the guide, holding the screen on each side would be fine, but the glass cracked almost immediately.I did not grab it by the corners, just the middle of the glass.
This glass is horrendously fragile. I don't think I can afford to repair the screen :(
Lowering the screen down at the end here does not need a suction cup. It sounds like you left something in the channel so you fractured the screen from the object (a loose screw?). I've done a ton of these systems and have not needed a suction cup at this step. I do agree a suction cup can be helpful in the screen removal process. just to give you a better purchase, not pulling! As you can damage the screen if you pull too hard.
Dan -
If there is a wire or cable underneath adhesive tape, always pull the tape off first.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Be extremely careful removing the LCD Temp Sensor from the rear of the screen. If you pull the wire, you run the risk of severing the metal wire from the connector but not notice it because the surrounding plastic insulation may still be intact. Use a razor blade so “shave off” the sensor under the adhesive. I just had the screen replaced by a local shop and, upon boot, the fan was running full-speed and the Mac’s speed was miserable; Excel took 30 bounces in the Dock to launch rather than the expected 4-5. Novabench showed the Mac running at 4% of its expected speed (overall). The tech examined the sensor carefully, found the broken connection, soldered it back into place, and all was fine. Note that the (partially disconnected) sensor actually showed up when I ran Macs Fan Control in an attempt to work-around this. No problem controlling the fan speed then but the iMac’s running speed was awful until the disconnected sensor wire was fixed.
Hi barryjaylevine,
I’ve had my LCD replaced on my iMac 27 / 2013 and there is no LCD Temp Sensor cable on the replacement screen.
I’m experiencing the same performance issues.
I’ve ordered a new sensor, do you have any pointers as to how to install it?
Thanks,
Simon
UK
hey Simon, I used 2-sided tape….this is assuming the new sensor doesn’t already come with an adhesive surface already applied.
a roll of kapton tape for your own peace of mind will make sure nothing detaches from thermally-induced adhesive crystallization
make sure you position it in such a way that you can easily plug the lead back into the mobo….not a lot of length to that wire
Howdy folks,
Thanks for all the tips, LCD sensor fitted and iMac back in action.
Never again!
Simon
Hello all. So I’m trying to pinpoint my backlight issue on my 2015 retina 5k - I noticed I’m missing my thermal sensor on the LCD. Would this help with the backlight? I’m sure it will keep my fans from going crazy. Any help would be appreciated! Note: I have LEDs except the 4th one. Thanks!
Use a Phillips screwdriver to remove the nine 3.2 mm screws securing the support bracket.
You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
I did not find it necessary to remove these screws and this bar
Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
No comments on this ?
It's quite possibly the most difficult part to put back in the entire process
The screws are tiny and the there is no easy way to line up the holes on the bracket with the screws
Having got this far - it wasn't even all that necessary to remove this part in the first place
Severe pain in the neck
With the right tools and technique, the bracket can easily be replaced in under a couple of minutes.
Use a screwdriver with a magnetized tip which frees up one hand and place a screw on the tip first.
Then line up the screw hole on just one end of the bracket and using a pair of tweezers from the side, hold the bracket in place while you put in the screw.
Next, do the same on the other end of the bracket. After that, all of the screws in the middle are quick to replace. I didn't really have to touch the bracket again after the end screws were in place.
Hope that helps someone else since removing this bracket does make later steps a bit easier.
Remove two 10 mm T10 screws.
I found i didn’t need to remove the speaker nor the hard drive. In fact I managed to remove the old PSU without even removing the chin strap. However, to install the replacement PSU, I had to remove the chin strap. So I would say, remove the chin strap, but you can optionally leave the speaker and hard drive in.
While you do not need to fully remove the screws as once you loosen them a few turns the speaker becomes free. I found that after the removal of the speaker, I turned it over and popped the screws out as this made it easier to replace it later as I could see the alignment before putting the screws back in. If not you may be off a little and you do not want to force the screw back in.
I used a pill container that I got from Walgreens to hold all of the fasteners I removed during the disassembly process. The container has 14 compartments (individual compartments for each morning and evening of the week). I put a small piece of paper in the compartment with the fasteners to note the name and step of the procedure and the size of the tool I used. Hopefully this will be useful when I go to put it back together again.
Unplug the left speaker cable by pulling it straight up out of its socket on the logic board.
De-route the cable from the gap between the hard drive and logic board.
I didn’t unplug and de-route this cable. Later, Step 29, has you remove the left speaker. This isn’t necessary. If you can just move the speaker over to expose the hard drive mounting screws, so if you’re not going to remove the speaker, you don’t need to unplug it.
Use a spudger to disconnect the power button connector from its socket on the logic board.
there is no need to disconnect the speaker, just unscrew it and move aside slightly to reach the HDD screws (about 5mm) - if you want to replace just the main HDD
Take note of exactly what direction this tiny little wire was.
The connector has a plain black side and the other side you can see the 2 silver connectors.. the side you can see the 2 silver connectors faces the front.. the plain side is to the back/against the logic board.
If I leave my iMac unplugged for an extended period, say 24 or 48 hours, is it still possible to get an electric shock from the PSU? Do the capacitors eventually discharge?
you can do this method, or just wear latex gloves.
make sure you’ve actually unplugged the mac when running this cable, and not had it plugged in to test the diagnostic LEDs, because one of those wee silver spots is carrying 230v, and its 6mm away from the place the cable runs, So if you have fat fingers like mine, that’s a free wake up zap
Lift the left speaker straight up, until the power button cable is exposed (about 0.5 inches).
This is MUCH easier to do if the support bracket along the bottom is removed first. See iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement step 25.
Use a P00.
To replace it, introduce it like in the photo at the link to be able to hold the right most holes of the chassis and bracket. Replace the first screw, align the bracket to the horizontal and add the screws from right to left. Each one will bring up the next hole in the bracket close enough to screw through. Reverse those directions if you are a leftie.
Gently de-route the power button cable from its groove in the left speaker.
Pay attention: if pulling out the loudspeaker tear off the wire of the power button, Apple have not any service parts except for the whole rear housing!
Use a P00.
Lift the left speaker straight up and remove it from the iMac.
Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
I found it wasn't necessary to remove the speaker from the left side to remove the hard drive. You can remove the screws, and then slide it over to the left — giving more than enough room to access the hard drive.
me too. don't need to remove it if you only want to change the hd
Agreed, wast of time to fully remove the speaker.
easier to remove the speakers if you unscrew the front ‘chin strap’ - 6/9 phillips screws that you can see in the picture hold that aluminum piece in place
Agree. This is MUCH easier to do if the support bracket along the bottom is removed first. See iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement step 25.
Use a P00.
Pull straight up on the SATA data/power cable to disconnect it from the drive.
Is the WD hard drive an Apple Special with some internal rom or other thing? Planning to put in a Seagate Firecuda 2TB. Is there some special plug or temperature sensor requirement? Seems like there is only the SATA connector. Will I encounter fast fans? (can load the software to stop that). Think it’s a swap and is “easy”.
Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
Left hard drive bracket screws are T8!! Had to remove HD first before derouting left speaker cable.
Thank you iFixit for sending a T10 with magnetic tip. You saved me!
The bracket screws are T10. The screws on the left side of the SILVER hard drive itself, are T8. If you seem to need a T8, you are actually trying to remove the wrong two screws. Look immediately to the left of the hard drive & you will see the BLACK bracket frame with two screws that use T10.
I can confirm that some models are indeed a T8 on both sides of the bracket (NOT the drive itself). I have two 2015 A1419 and one is T10, the other T8
mine were T8s
Bracket to iMac case screws,T8.
Which is fine.
Just as in the next step, T8 or T10.
Grab the hard drive and left hard drive bracket together.
Tilt the left side up away from the rear case, and slide the assembly to the left.
Remove the hard drive and left hard drive bracket from the iMac.
Two notes here: If you are using OWC’s Thermal Sensor HDD Upgrade Cable, be sure to tuck the cable under the hard drive slightly. You cannot allow the connector to sit near the top edge since this will not allow the monitor to sit flush with the chassis when it is reattached. Additionally, the SATA connector does not seem to fit together as snuggly as when it was connect to the HDD, so tape or a plastic cable tie to keep the connection tight may be good insurance to prevent it from coming loose.
If you are planning on dual booting with Windows 10, the Windows 10 installed failed when the SSD and HDD were both connected at the same time. I had to disconnect the HDD until Windows 10 was installed. Note: I did a fresh install on a new SSD not configured as a fusion drive. If you are planning on doing this as well, use packing tape (or something similar) to hold the monitor in place until after installing the OSs. Then reconnect the HDD and apply the adhesive to the monitor for a permanent seal. Good Luck!
Hi Walter, i’m looking to replace the broken fusion drive with a SSD, do i have to get the OWC’s Thermal Sensor HDD Upgrade Cable?
Full removal of the speaker is unnecessary - just very carefully unplug the two-conductor power button cable, which is routed through the groove along the edge of the speaker enclosure. Next, unfasten the two large torx screws holding the speaker enclosure to the chassis. Now you can easily scoot the speaker away from the drive mount - move it over just enough to reach the drive mount’s 2 torx fasteners beneath the edge of the speaker (a CM or two). There’s now enough room to easily remove and replace the drive assembly .
Just wondering if the HDD 3.5 (3TB) in my 2015 27’ 5K iMac case are the ones with the temp control firmware onboard. Just got quote from Auhorised repair centre for 2x the normal price of a 3TB drive. They say I can drop in one i source myself if I like but I don’t want to get it back and have the fans run all the time. Thanks in advance :)
Remove the left hard drive bracket.
This step is unnecessary. Just leave the bracket in place and set the assembly aside.
On Late 2015 27” iMac I found that after removing this speaker, and the Right side one, I could reach under the motherboard and squeeze and disconnect the SATA data connector with a needle-nose and then remove the SATA power connector and slide the cable out from under the logic board without removing the board. The new cable slid in from the hard drive side with little effort.
If switching to an SSD, the posts on the drive can be removed and used on the 2.5” to 3.5” adapter tray.
Disconnect the power supply control cable from the power supply.
I found this cable very difficult to disconnect, be very careful because the cable is between a black tape and it's stuck very hard to the logic board and the cable is very short and you don't have space to move and separate it from the connection! Be patient and take the time you need
I found than putting the flat end of the spudger at the center of the cable, and tilting it got the cable out without an issue.
I was able to use the flat end of the spudger on the sides. You can see a tiny little clip on each side. Be very gentle!
These connectors seem pretty tough to remove until one understands the latch. Each side of the plug are two little sprung tabs (the tab is part of the spring clip which runs down the side of the plug on each side - makes sense once you see the removed plug!). Squeeze them in towards each other and then gently pull the plug from the socket. No great force, or even the spudger, needed once that is done.
One more tip, has worked on other cables for me. Fish the skinniest spudger tip you have under the cable, and with a finger of your other hand put opposite pressure on the cable against the spudger and gently work it out
If u are right handed, i can recomend to use your index left nail to press de bottom sprung, and a flat spudger on the right hand, came off so easy
If you have a insulated long nose pliers along with a splugger and can get underneath the cable WITH the long nose pliers on the RIGHT side of the cable, towards the logic board, with the splugger on the LEFT Side of the cable doing the same, you can get the leverage to GENTLY pull this cable out very easily.
Remove the following four screws securing the power supply to the rear case (size T8 or T10 depending on the exact model):
Two 23.7 mm Torx screws
Two 7.3 mm Torx screws
Move the power supply board towards the left edge of the case and up to free it from the notch in the logic board.
Use a P00.
The top right screw on the power supply actually screws into a stand-off screw connected to the back of the iMac case. Once you have removed the 4 x Torx 8 or 10 screws you can move the power supply enough to see the upper face of it.
It has a Torx 25 slot in it and comes out easily. This will give you a lot more room for your fingers in Step 40, depressing the tab on the DC power cable connector to pull it out, and when replacing it on reassembly. You may find it won’t require you removing the support bracket as in the suggestion above.
Depress the tab on the DC power cable connector, then pull it straight out of its socket on the back of the logic board.
Remember to push in the disconnect tab on the large connector. Carefully insert your finger and push on the tab before you pull on the connector.
Thank you Manuel, this was a tricky one.
Yes, I pulled the whole socket out because I didn’t know about the tab. Fortunately I was able to place it back in. Not sure if it was glued or how it was anchored but it seems to have a solid connection and I can’t easily pull it out by hand. Once I plug the power cable back in should be ok.
This connector was very difficult for me to remove (even after pushing the disconnect tab). Eventually I had to use a pair of needle nose pliers to wiggle it back and forth out of the socket. A lot of the cables on the my late 2015 model were very tight and a struggle to get out.
I'm struggling with this step. I presume that the tab to which you are referring is behind the connector. I can see a plastic protrusion there but it does not move when I push it. Just to get my finger behind it requires the power board to be moved quite a bit btw.
i could not get it out by the force of my fingers, so what i did was slightly turn the imac 90 degrees so i could reach the area better, push up (so, vertically) the power control board, push in the tab on the bottom of the connector with my right hand, and slightly wiggle the connector out of its socket with a plier
Left index finger pushing on the tab from behind the connector, using needle pliers in right hand to rock up & down did the trick thanks @starfleet_tone
Just be careful! I’ve seen two systems where the socket was pulled fully off! So the logic board then needs repairs or replacing being just a bit too aggressive!
Dan -
Needle nose and wiggling worked for us too. We were stuggling like heck with it when just using hands!
This is MUCH easier to do if the support bracket along the bottom is removed first - more space to angle the board upwards. See iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement step 25.
Use a P00.
I did as Andrew Gough did, per other videos reviewed. Removed it right away. Just makes things easier, more space for just a few screws :)
I used your suggestion to remove the stand-off and then used my left hand index finger to press the tab while rocking the connector side to side with a needle nose pliers. Plug came out easily.
The tab is a pain in the a$$$ to get your finger in there. I was so horrified at the size of the capacitors that I put on gloves to reduce any amount of shock :-) . To get it loose I would pull out carefully the power board as far as I could than I wedge my index finger under and press the tab and slowly pull until I saw a slight gap between the end of the socket and the plug. I than place the flat part of the black spudger or blue one into the gap and use as it as a wedge to help move the plug forward as I kept the tab pressed.
Flip the top of the power supply towards you, like opening a mailbox, to reveal the AC inlet cable connector.
Disconnect the AC inlet cable connector.
To reassemble, do the same in reverse but keep power supply board more upright than slanted down when re-inserting it in to the lower right corner. The lower right screw post has an protrusion under/behind it and the Power Supply's small 2 wire plug must fit between the front of your Mac and the obstruction. Then it just slides right in and then screw it down.
Wear gloves when doing this to reduce any shock. The size of those capacitors are very unnerving and scary. Also those solder joints.
Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board.
Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
Pull the connector to the right to remove it from its socket.
Lift the speaker straight up and remove it from the iMac.
Did this tonight. I couldn’t get the right speaker out. But I was able to move it far enough to the right to be out of the way of the logic board.
You have to remove the five small screws on the lower edge of the iMac to remove a strange bracket or something, like the 21.5” 2012->… iMacs
Same here. 2013 27”. If you remove two of the tiny screws along the bottom edge then it comes out.
Use a P00.
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Peel the black tape connecting the fan to the exhaust duct back slightly.
Leave the tape in place on the exhaust duct—you only need to expose the joint to free the fan.
Remove the fan from the iMac.
Use a piece of tape around the antenna cables to keep them in the same order, makes reassembly a little easier.
Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
Leftmost
Top
Upper right
Lower right
My iMac has a slightly different assembly. There are 2 - T5 torx screws holding little clamps for each cable (2 clamps per screw). Certainly more secure but another size screw to deal with…
My iMac also same with Greg mentioned. need to T5 torx driver. A1419. Late 2015, Korean Version.
My 2017 has long WI-Fi card, It’s It’s a M.2, cuz no remove antenna. Undo WI-Fi card fix screws and pull out card. Easy one.
Before I disconnect the cables, I use different color sharpies and draw a different color on each one’s head & then I take a picture of the cables connected to the board. Pic is my reference of which cable goes to what connector.
I have a 2017 and I agree with Tanya. There are 2 T4 screws fastening the airport card to the motherboard. It’s easier to remove these and gently pull the airport card straight up out of the motherboard while leaving the 4 antenna wires fastened. You can’t see the connector or the airport card as it’s on the back side of the motherboard but just wiggle it side to side while pulling straight up and you’ll have no problem. I’ve broken off those tiny airport connectors in the past and it’s no fun replacing them.
same as Greg, did with the torx t5
I have a 2019 iMac and we needed to use a T4 screw
My late 2015 has a Airport/Bluetooth card secured with two T5 screws. After removing them you can just wiggle and unplug it from the logic board, without needing to fiddle with the antenna connectors.
Same as the other comments, in my iMac 27” retina 2015, the WiFi/Bluetooth board is a bit longer and the 4 coax cables are fixed by 2 T5 screws…
When reassembling a removed WiFi card keep 4 antenna leads attached as mentioned by poster (tanya et al) when reassembling as you replace logic board keeping it tilted forward helps in aligning the notch on card for easy reassembly and T3 screws replacingonce card is firmly seated.
Flip up the metal retaining bracket on the iSight camera cable.
Pull the camera cable connector straight out of its socket, toward the top of the iMac.
Use the flat end of a spudger to disconnect the headphone jack cable connector from its socket on the logic board.
Gently push the cable out of the way.
On my 2017 iMac there is a tiny little cable and connector on the motherboard that is approximately half way along the motherboard and is connected down towards the base of the case. It came free easily when I removed my motherboard but just wanted to remind people to reconnect!
It’s the microphone cable!
Lift upwards with the spudger/fingernail, rocking it up back and forth.
(For those who have not seen this style of connector.)
Remove the following screws from the front of the logic board:
Two 23.7 mm T10 screws
Four 7.4 mm T10 screws
One 20.8 mm T25 spacer screw
One captive T10 screw
The central screw is very difficult to reach! Use a long and very thin T10 screw driver
On my late 2015 there is another T10 (approx 16 mm long) on the lower edge slightly left of the hole in the logic board giving a total of 4 screws along the bottom edge.
My 2017 has small flat cable and connector on logic board. And all screws are changed to T 9
My 2017 had all T8’s, including the captive screw beneath the motherboard
Late 2015 iMac - mine had all T8 screws and 4 along the bottom row
On 2019 iMac
Red = T8
Orange = T8
Green = T8
Yellow = T25
In 2017 too.
2017 here.
IMPORTANT - note Tanya’s comment. The narrow flat cable in the middle - it’s the mic cable on a *tiny* ZIF. See iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement
Also has the extra bolt middle lower edge.
All T8 except the yellow T25.
In my iMac 27” retina 2015 all screws are T8.
There is also an another T8 screw between the left and central “orange” on bottom of the CPU board
Just completed and removed logic board. All my screws were T6. The screw beneath is a captive screw, stays retained in the fixture after unscrewing.
There is a 25T stand off that is not listed. It is not on the board but beside or underneath the yellow/red on power supply side.
Pull the cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port.
Anyone know if models that shipped with only a bladed SSD have the SATA cable still inside? I’m guessing probably not, but haven’t been able to confirm anywhere.
The cable was so stiff, I didn’t try to pull it through the bracket. Instead I removed the upper screw holding the right HDD bracket in place. Then I rotated it counter clockwise enough to just move the cable behind it and out of the way. Once I did that, I screwed the bracket back into place. I reversed the process when I put the machine back together. It’s a Torx-10 BTW.
Excellent tip, Kenneth! I did the same, made things easier.
Jesse, no SATA cable inside. My iMac came only with the blade SSD and an empty HDD bay, so I have to buy the SATA cable separately.
the card drive cable is affixed to the heat sink with some sort of adhesive. If it is not placed back similarly, the system cannot sense the heat sink temperature, and the fan will run at full speed continuously. I used double sided tape and pushed it back in adhered position after re-attaching logic board.
Remove two 5.7 mm T10 screws from the top of the heat sink exhaust duct.
My model (2015) had another screw holding the heatsink duct and a stand-off holding the whole thing attached to the back. Even gently moving the logic board almost got the duct damaged till I realised what was going on so I’d suggest to be careful and DO NOT pull the logic board if it looks like it’s still attached - most likely it is!
Carlos,
I am at a bit of a loss. I have a 2015 as well and removed everything else, but the motherboard is still not moving. I found the two, as shown in the picture, but can't find a third one anywhere on or around the heatsink duct. Any help is sincerely appreciated.
Marc
MarcW58 -
Ditto for the 2013 27”. One extra screw
My model 2546 late 2012 has 2 screws on heat sink shroud. First is on left side. The right can only be accessed with board tilted out a bit.
I just finished disassembling a late 2017 27” Retina and for the life of me I couldn’t get the logic board to come out. What. I discovered was that there is a part of the heat sink shroud that is held in place by a stand off boss for the power supply. You will need to remove the stand off boss using a T25. Remove carefully and save for reassembly…
Same here for late 2014.
Yes, there is a screw holding down the fan shroud it is an angled black part where the guy's left hand index finger is located in Step 56
Tilt the logic board slightly forward.
Lift the logic board straight up and out of the iMac. Be careful not to snag on any of the screw posts attached to the inside of the rear case.
The 2017 iMac has a small cable with a ZIF connector coming from the bottom of the machine that needs to be detached from the logic board before it can be removed.
I can confirm this. As i recognized the cable after i removed the logic board i had some trouble to find the spot where to plug it in.
If you are having a hard time removing it, you might have forgot to remove the spacer rod when you removed all the motherboard screws. In my case, it was a T20. This is in my late 2015 the case. Just like Eric said 11-01-2020.
Same for late 2012. For those curious the spacer is just to the left and appears to attach to the heat sink.
The iMac 27” didn’t come with the PCIe SSD card so of course there wasn’t the necessary screw to mount one.
Here is the screw to order;
https://www.ebay.com/itm/283482947478?ch...
What I did was find a screw that fit. Happened to be the case screw from the iFixit external 2.5” case but since that was a countersunk screw, I fabricated a washer for it.
When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
You can use a USB flashdrive or ethernet cable to ensure the logic board is seated correctly while you screw it in.
To help me line up the IO ports, I filled all the USB ports on the back with thumb drives before I screwed the Logic board back down. Worked like a charm!
Thanks Alex :)
iMac (Retina 5K, 27-inch, 2017) の場合、Thunderbolt 3(USB-C)ポートの位置がシビアです。
Ethernet、USB 3ポート、Thunderbolt 3(USB-C)へ最低でも各1本(合計3本)を差し込んだままの状態でロジックボードのネジを閉めるようにすることを強くおすすめします。
EthernetケーブルとUSBメモリの2本を挿して調整し組み上げましたが、最終的にThunderbolt 3(USB-C)が刺さらないことが後で判明し、結果組み直しをしなくてはいけませんでした。
For iMac (Retina 5K, 27-inch, 2017), the location of the Thunderbolt 3 (USB-C) port is severe.
It is highly recommended to close the logic board screws with at least one cable each (total of three) plugged into the Ethernet, USB 3 port, and Thunderbolt 3 (USB-C).
I plugged in two Ethernet cables and a USB memory stick, adjusted and assembled the board, but in the end I found out later that the Thunderbolt 3 (USB-C) would not stick, so I had to reassemble the board.
Translated with www.DeepL.com/Translator (free version)
貴重な情報ありがとうございました!
I do this job fairly frequently and I have a small box in my iMac tool kit containing a headphone jack, four USB drives, a short two-ended Thunderbolt cable and the end of a red moulded Ethernet cable to keep things aligned from the back when screwing the logic board back into place.
I loosely screw all the screws in, then tighten them gradually, going round the board several times to make sure it lands in exactly the right position.
Pull up on the SATA power cable connector to disconnect it.
Unplug the SATA data cable connector by depressing its locking tab and pulling straight up on the connector.
Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
Is this picture correct with 7 pins? Or is it form the 5k version? (See comments on that case below).
There is an cable on eBay with 5 pins.
This guide was written the year before the 5K model first came out. The cable in the photo is definitely for the model listed, although it’s always possible Apple made more than one variation.
Hey, if you got this far and your iMac is getting along in years, maybe pick up a BR2032 battery and replace the PRAM battery while you’re at it, as you have to get to this point to access it.
I'm waiting on the battery now! I have a CR2032 in the house, but I looked them up, and they're too different to make me comfortable using one. And I accidentally ordered the BR3032, AAAGH. Sigh. Stupid Amazon put them side by side, and I clicked on the wrong one. :) Must've been Amazon's fault. :) But for sure, I was looking at my computer in pieces, and I looked at that battery, and I thought, wait, when was this thing built? 2017? Um. Might be time for a change.
Tom, great tip on the battery. I put a new one in my 3½ year old iMac.
Could have used a warning that this cable is not present in models that shipped with a SSD. I was replacing my blade SSD and adding a new SSD at the same time, only to find that I was missing this cable while my iMac was in pieces. Had to reassemble it without adding the SATA SSD, major hassle.
This is a bit of a grey space.
Clearly you don’t need the cable if you are replacing the HDD or switching it out of a SSD. Its only when you are enhancing your system by adding a drive which you didn’t have before.
Dan -
Hello congratulations on your ssd blade upgrade. Have you used the owc blade or a samsung + adaptor? Regarding the cable, do you know if we can buy the cable and plug it into the logic bard so to add another ssd in the aluminum frame ? thanks a lot have a niceday
Patrick -
@patrick7508 - I encourage you to stick with a pin-compatible drive not use a M.2 adapter as they are not reliable and some drives are not compatible. Stick with a real Apple drive or OWC. Just think of the work you needed to do just to get to the drive.
Dan -
Remove the single 5.3 mm T8 screw securing the SSD to the logic board.
What type och screw is this? I just need the measurements, is it a standard M-size screw?
Did you find out any details about the screw in the end?
djones -
I am also searching for the right screw. There wasn’t one there before as there was no M.2 SSD there before (late 2015 iMac with HDD configuration). It’s definitely smaller than the T8 Torx’s I have been taking out so far.
Boris -
I bought the 1TB PCIe SSD for my 5K iMac (late 2015). Worked like a charm without any hiccups; great vendor: https://beetstech.com/product/solid-stat...
I have bought an iMac 2015 with 3TB Fusion drive, from which the SSD blade was out of order.
A serviceman had split the Fusion drive and the iMac ran on HDD only. Awfully slow...
On the top of it the boot time was very long since the bootloader waited 3 minutes for the defective SSD to show up.
Since I had an Apple 121GB blade from an upgrade on a Macbook Air I replaced the SSD.
Now my iMac boots directly from the 121GB blade (AFPS), lightning fast. The 3TB HDD is HFS+ and holds my user files and Time Machine. -
Lift the end of the SSD up slightly and pull it straight out of its socket on the logic board.
What do you mean? I'm going to buy a ssd to add it in my imac 27 late 2013 the came without it.
Which part I need?
I think what he meant to say is the SSD shown (Samsun) is for a late 2013. The 2014 iMac uses a Sandisk unit (see the 5k teardown).
Ifixit have made the mistake of referencing the late 2013 iMac teardown photos here.
Brent -
Not get confused! Apple used different vendors of their SSD’s both SanDisk & Samsung supplied SSD’s in this series.
Dan -
For the 2012 iMac 27”, I can confirm the Blade SSD is an 8+18 pin SSDD and I believe this is a SATA drive, NOT a PCIe (NVMe) drive. I took my 2012 apart to try to add an NVMe drive with 2013 macbook adapter, and it does not fit. I didn’t have an adapter that worked so I just replaced the 3.5” HDD with a 2TB SATA 2.5” SSD and left the blade slot empty.
The SSD drives available from OWC have speeds consistent with SATA drives, so I think the benefit of replacing or filling the blade slot are pretty minimal unless you’re really trying to maximize your available storage space, in which case it’s likely better to invest in an external or network attached solution.
TL;DR 2012 iMac is an 8+18 pin setup that is likely SATA, not PCI-E so just replace the HDD with a big SATA drive.
Here’s a good source of info The Ultimate Guide to Apple’s Proprietary SSDs And BeetsTech is a good source for the SSD’s
iMac 27” 2019!
I did it ;-) and ist works fine … but I had no microfon after reinstall. I had put the adhesive strips over the mic holes.
So I need to open again with a new pair of adhesive strips ;-)
I Have installed a Samsung NVME SSD 970 EVO 1TB with the “long” sintech adapter and a Sandisk Ultra SSD 2TB (SATA).
I am about to do this to my 27” late 2015. Haven’t decided on which Blade SSD to use yet. But I have bought af Crucial MX500 2 TB SSD SATA.
I have read a lot of problems with the Samsung NVME SSD 970 EVO.
Also read a lot about needing a SATA cable from OWC (OWCDIDIMacHDD12) In-Line Digital Thermal Sensor for 27-Inch iMac, to ensure the fann does not spin uncontrollably.
Have you had any problems with your setup with the Samsung SSD, and did you use the OWC cable ?
Lars -
I also did it with the same adapter, ordered for a few bucks from china.
I’m usign the 970 EVO Plus 1TB, they have updated the firmware and it works out of the box.
The firmware for older models can be updated directly on the mac with the updater from Samsung (can be installed on a USB stick and used to start the mac with it)
The standard 970 EVO does not have had the firmware issues, just the Plus had in the past.
For the blade SSD no OWC cable is required, that is only if a SATA-HDD is replaced by a SATA-SSD, thats a completely different thing.
maccy -
Is there supposed to be a heatsink attached to the replacement drive? I don't recall receiving one in the OWC package and I am seeing temps hitting 190 F (almost 88 C) under heavy load.
No heat sink on the blade SSD, you could add one but it won’t really change what you are facing here.
It does sound like your SSD maybe to small (and/or your system needs more RAM) given what you are doing.
Keep in mind boot drive (SSD here) is used for virtual RAM, caching and depending on the app scratch space. You want to leave at least 1/4 of the drive empty for best performance. 256 GB or smaller drives will need 1/3 reserved.
Dan -
How to boot the system after replacing the ssd? Where is the recovery partition? I have followed all the steps but the screen is black and not even the question mark is displayed.
Then you have an issue with your installation as you should be treated with a flashing question mark. Check your displays connections and maybe see if an external display works. Did you use the proper tools and technique within the guide to lift the display off? Many people have damaged the display in the process if they don’t follow the guide to the letter.
Dan -
Installed a 2019 SSD in my late 2015 iMac retina, purchased from fast_macs on eBay AOK with nearly 1900MB/s write 1800MB/s read (ish). Also installed Apple 2TB drive too whilst I was doing it.
The 2017 and 2019 SSDs should be the same (or very similar). Both are SSPOLARIS and the same generation. I’m in the middle of doing the same on mine (mid 2017), going from a 2TB Fusion to a straight 1TB blade.
I purchased this one, based on the excellent feedback:
If I install a new 2TB SSD to replace my HDD (2019 imac 27), do I have to install a new logic board SSD? I’d rather not have a fusion config any longer (S/W seems buggy - hence my fusion drive problems). I’d much rather have just the new 2TP SSD in place of the old HDD, if possible?
Replacing your SATA HDD for a SSD makes a lot of sense! Any size will work.
You should pull the blade SSD which was mated to the HDD to create the Fusion Drive pair.
Dan -
Thanks Dan - blade SSD to be discarded!
Hola. Quería saber que iMacs de 27” pulgadas llevan ese tipo de conector M2. Gracias
@chucklott I'm in the same situation as you were. I have a new 2.5" SSD in-hand and would like to just use that, and pull the existing blade SSD out. I think I have to purchase a SATA cable though, because the iMac doesn't appear to come with one. Is that what you did too? Any other issues that you encountered with your fix?
Depending on what your system was configured with for drives you may have the needed cables.
The low end config came with a SATA HDD as such you will have the needed SATA cables
If you bought the Mid tier config then you have a Fusion Drive which is really two physical drives the SATA HDD as well as a small blade SSD which is used as a cache drive (not visible from within the OS or Disk Utility as a mountable volume) again you will have the SATA cables. But you will need to remove the blade SSD as it gets in the way.
The last config is the high end which is where a much larger blade SSD is installed this is the only config that will require a SATA cable.
These setups are independent of the CPU/GPU the system also offered.
Dan -
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
63 участников успешно повторили данное руководство.
15 Комментариев
Guys, After I replaced the HDD with a SATA SSD in my about my mac on storage it doesn't say Flash Storage but Solid State Drive. Can I change that writing into Flash Storage. I will have problems reselling it, people may think it was defective and repaired. If anyone knows how to do that please let me know. Thanks
Theres no way to change this, its because flash storage and Solid state drive are similar but not identical tech, just be honest when you resell and say you replaced the drive.
I'm having trouble finding out what kind of SSD the 2013 27" iMac uses, as well as where to buy one. Trying to add one to an iMac that was configured without one when shipped. I read that this model still has the port available, and I'd like to make a fusion drive. Can anyone give me a good source for buying one?
Hi Andrew. Did you do it? Can add the ssd disk?
thanks!
I'm trying to do the same thing Andrew! I have a late 2012 model that has a 1.2TB Fusion Drive,, which is the original 1TB drive with a 200GB Crucial solid state drive, and it's AMAZING! I want to do the same thing to my late 2013 27" iMac, but I heard it doesn't have the same port available as in the late 2012. Does anyone know this for sure?
Hi . Did you can add the SSD disk?
thanks!
Late 2012 and Late 2013 iMac use different SSD ports.
Hi
I have a 27” late 2013 with 256GB PCIe and would like to add a 1TB SSD to the hopefully built in HD-connector. Does anyone know if this is possible?
To add an off the shelf 2.5” ssd/3.5” hdd to an iMac 2013 you will need an “in-line thermal cable” from OWC, so the fans don’t go crazy (Apple HDs have special firmware in hdds with temp info being sent on power cable) , they also sell a 2.5” to 3.5” mounting bracket
joel -
Does a non Fusion Drive iMac comes with SSD screw (Step 56)?
No, you’ll need to get one if you are adding the blade SSD.
Dan -
If my iMac didn’t have the fusion drive added originally, does the slot still exist to add it in later? I removed a 12+16 drive from a MacBook Pro and know it would fit if the slot exists.
All of the 27” models have the blade SSD connector. Double check your SSD here to make sure its the right one The Ultimate Guide to Apple’s Proprietary SSDs
Dan -
Great guide, however the blade ssd OWC Aura Pro X2 SSD in the link, is not suitable for this iMac. The interface is a 6G MSata with Apple propretiary Gen 2A connector 7+17pin. You can use a M.2 NGFF to A1398 A1425 (2012 & Early 2013) Adapter MacBook Pro Retina SSD Replacement, B Key SATA Hard Disk Drive HDD Converter Card + a short M.2 Sata SSD like the Transcend SSD 42 mm (430S series). Should you want to save the work, an USB 3.0 drive is practically as fast if you do not mind it sitting outside the chassis. You may also utilize the Thunderbolt 2 port to reach double speed up to 10Gb, however you need an expensive Thunderbolt 2 enclosure that are hard to find or you may use Thunderbolt 3 enclosure that gets external power + Apple thunderbolt 2 to 3 adapter (that does not feed power trough to Thunderbolt 3 device).
Nope! The Late 2013 is a different blade SSD than the older 2012/early 2013 model which has the mSATA 6.0 Gb/s interface which you are pointing to.
iMac13,1 models Vs the iMac14,2 which offers the NVMe/PCIe x2 interface. So the OWC blade SSD will work just fine!
In any case I really don’t recommend using M.2 SSD’s in iMac’s given how deep you need to go to replace it when it fails.
Dan -
This instruction page is not clear and is ambiguous if you have to do all the steps to just change the power supply please clarify another words do I have to remove the speaker and the hard drive to replace the power supply?
crawfordjohn - Ответить
This is a display removal guide not the power supply guide!Here’s the guide you need to follow for that iMac Intel 27" EMC 2546 Power Supply Replacement
Dan -
Didn’t need the cardboard wedge to remove the display. Waste of money. Lay your Mac on its back.
James Clive - Ответить
Die verlinkte Karton-Reparaturhilfe ist für den 21"-iMac. Passt sie auch 1:1 für das 27"-Modell?
Stefan - Ответить
