Введение
Removing the display on the iMac Intel 27" Retina 5K Display requires cutting adhesive with a specialized iMac opening tool. After you've completed your repair, you'll need to follow our adhesive strip replacement guide to scrape off the old adhesive and replace it with new double-stick adhesive strips.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply.
This procedure involves removing the faulty/broken display, as well as transferring the display data cable and thermal sensor to a new display.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:iMac Intel 27" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
Run the tool up along the left side of the display.
Continue wheeling the tool up around the top left corner.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Set the iMac face-up on a table.
Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
Slide the card toward the center of the display, to cut any remaining adhesive.
Put the card into the corner again and let it stay there to keep the adhesive from resettling.
Insert a second card into the gap between the display and frame in the top left corner.
Gently twist the card, slightly increasing the space between the display and frame.
Slide the plastic card toward the center, again stopping just before the iSight camera.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
While holding the display up with one hand, use the other to unplug the display power cable.
Flip up the metal retaining bracket on the display data cable.
Disconnect the display data cable.
Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
Repeat this step with the other adhesive strip and remove it.
Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
Gently set the display face-down on a sturdy, flat surface. It may be helpful to put it on a towel or cloth to protect it from dirt or debris that can scratch the front glass.
Use your fingernail or the pointed tip of a spudger to flip up the retaining flap on the display data connector.
Pull the display data cable connector straight out of its socket on the back of the display.
If necessary, use an iOpener to heat and soften the adhesive on the two pieces of tape holding the thermal sensor in place.
Use tweezers to peel the tape off of the thermal sensor and its cable.
Slide an opening pick under the thermal sensor to separate it from the display.
Disconnect the thermal sensor from its socket on the back of the display.
Remove the thermal sensor and transfer it to your new display assembly.
You may need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display and transfer any missing components.
You may have to transfer the foam cushion pieces on the back of the display. Slide an opening pick underneath the foam pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
5 участников успешно повторили данное руководство.
2 Комментариев
Does iFixit have lists of Apple 3rd Party repair shops that you know are competent and can recommend? I just cracked my 2019 iMac i9 27” screen when a self-shutting door caught the edge as I carried it through. The crack runs from the right edge to about 5 inches into the glass. I live in Sarasota, Florida.
Is it possible to use a salvaged screen from a discarded iMac as a replacement for my functioning iMac? Does that up the difficulty? Both are 27" 2019 iMacs.
