Введение
Prerequisite-only guide for displacing the speaker in order to access the HDD.
This guide includes instructions to loosen the left speaker. This shortens the existing iMac HDD guides, which instructs fixers to remove the left speaker and lower support bracket.
Запчасти
Детали не указаны.
  1. iMac Intel Speaker Displacement for HDD Guides, iMac Intel Speaker Displacement for HDD Guides: step 1, image 1 of 1
    • Use a T10 driver to remove the two 10 mm screws securing the left speaker.
  2. iMac Intel Speaker Displacement for HDD Guides: step 2, image 1 of 2 iMac Intel Speaker Displacement for HDD Guides: step 2, image 2 of 2
    • Shift the loosened left speaker to the left—enough to uncover the hard drive bracket screws.
  3. iMac Intel Speaker Displacement for HDD Guides: step 3, image 1 of 2 iMac Intel Speaker Displacement for HDD Guides: step 3, image 2 of 2
    • Pull straight up on the SATA combo cable to disconnect it from the drive.
  4. iMac Intel Speaker Displacement for HDD Guides: step 4, image 1 of 1
    • Use a T8 driver to remove the two 7.3 mm screws securing the left hard drive bracket to the rear case.
  5. iMac Intel Speaker Displacement for HDD Guides: step 5, image 1 of 3 iMac Intel Speaker Displacement for HDD Guides: step 5, image 2 of 3 iMac Intel Speaker Displacement for HDD Guides: step 5, image 3 of 3
    • Grab the hard drive and left hard drive bracket together.
    • Tilt the left side away from the rear case, and slide the assembly to the left.
    • Remove the hard drive and left hard drive bracket from the iMac.
  6. iMac Intel Speaker Displacement for HDD Guides: step 6, image 1 of 2 iMac Intel Speaker Displacement for HDD Guides: step 6, image 2 of 2
    • Remove the left hard drive bracket.
Заключение
Arthur Shi
Участник с: 03.01.2018
202 085 Репутация
Автор 436 руководств
Команда
iFixit Участник iFixit
Community
145 членов
Автор 15 528 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 66
